Hi to all,
I own a 2011 1.4 Petrol Punto Evo for 2 years now. I'm having this problem simce day 1. And there it is:
When I start the car, the ASR/ESP light is turned on on dash and i get the ASR, ESP and Hill Holder failure massages.
Now - if i turn the engine off, and turn it back on it will disappear and everything works perfectly! Important to say that ABS works fine.
As i said I'm having this problem for 2 years now, so i looked it up several times. The options i came up with are:
1. Spiral Clock Spring problem - some said it might be the problem since sometimes the Steering Wheel light also turns on with the Check Steering Wheel warning. It happens about once or twice a week, i turn the steering 2 times and it disappears - does not affect the ASR/ESP problem.
2. Breaks problem - some Fiat mechanic told me it might be be cause of a back breaks light circuit shorted. About that i know i have a crack on both back lights plastics.He also suggested the I might have a problem with something called Braking Unit.
3. A breaking sensor problem behind the breaking pedal - may be, i do know that the loghts work fine.
Anymore thoughts? Anyone experienced that restart engine fix and have solved it?
