dtlove
Hey,
So I've just got back from a week away with my family. It was a 5 hour drive down and everything was fine, but the next day I went to set off from the site and there was what I can only describe as a heavy juddering with the car in the first gear. Since then it's happened almost every morning when setting off, but goes away and won't happen again until the car has been left still for the night.
I've done some reading and so far have had so many different answers, such as bad plugs, problem with the flywheel, driveshafts, engine mounts or just bad driving.
I've had the car since April and I know what it takes to stall it, the revs have not been low enough, and setting more revs just makes the juddering slightly more noticeable.
My theory is a potentially worn/damaged clutch as getting into first is slightly harder than it used to be, but not awful.
The juddering is definitely more aggressive than a stall, and noisier too.
Plugs are new as of May and have been fine, plugged in a scanner and no codes being read either.
Does anyone have any suggestions?
Edit: I should also add that this only ever happens in first, with my foot somewhere on the clutch. The juddering carries on for a second with my foot off the clutch.
