General spare wheel
General spare wheel
puntodad19
Member
I have read all the spare wheel prompts that come up but I am just finally checking....
the lad has a 2010 punto evo 1.2 active with 175/65 - 15 tyres and steel wheels, which hopefully the the standard wheels the car came with.
The boot does not have a spare, even a space saver one, but has the black plastic tray with the compressor and not much else.
I read that the plastic try is held in by one bolt and is removable.
Will the standard wheel and tyre mentioned above fit in the spare wheel well please?
If it will then we will get a wheel and tyre the same standard size etc. and breath happy.
Please confirm.........
the lad needs the car ever day and evening for work so we dont have the time to jack up the car and remove a wheel and try as see if that fits, but if needs must we can do that.
Anyone fitted the standard wheel mentioned above into the spare wheel well and any problems come to light on this??
Thanks in advance....
Hopefully the amazon haynes manual will arrive this week so will do a post about what they say about earth points......
Just be sure to get one from a punto evo or grande, older punto’s up to 2006 can have a different bolt pattern.
the lads is a punto evo 2010, but will check pcd etc..
