Jamiehill1990
- Jul 18, 2019
- 2
- 1
Hi there. Was wondering if someone may be able to help me. I’m working on a 2011 Punto Evo with stop start. The initial issue was a fault airbag control module. It was replaced with a second hand one that had the crash data erased on it. After fitting this airbag module the Engine management light has illuminated and is showing code P1850-15: Neutral position switch short circuit. I know that the vehicle never had this sensor from standard and the stop start would have worked via the clutch switch. something in the engine ECU has to be configured incorrectly by me. Does anyone have any suggestions? Many thanks.
