Old 03-07-2019   #1
Unhappy Electrical Rear sidelight fault
Hi
My rear side lights will not turn off, not sure where to start on this one although i do have to disconnect the battery at work and at home at end of every trip. I've checked the wiring on the Boot hatch and it looks like the wires have been bodged at some point, but then i was told the wiring for the lights doesn't come through the boot anyways apart from top brake light.
Any idea on what i could try would be greatly appreciated.
SparkyMcGorie is offline Reply With Quote Quote
Old 03-07-2019   #2
varesecrazy has donated!
Quote Originally Posted by SparkyMcGorie View Post
Hi
LEDs..??
Do the bulb segments work normally..
Just the LED tail lights proving bad?
Charlie
varesecrazy is online now Reply With Quote Quote
Old 03-07-2019   #3
Re: Electrical Rear sidelight fault
It could be something as simple as a stuck relay.
I’d still sort out the wiring for the boot first, there obviously is wiring into the boot for the 3rd brake light so it’s possible this could be feeding some current back some way to the tail lights, if something was shorting.
I’d check the relays by pulling them and seeing which one kills the lights when it’s removed.
Swap it with another identical relay and see if the lights then switch normally.
Maker and voice behind the YouTube channel PuntoHowTo 10k subscribers canít be wrong
And now the owner of a shiny new PuntoHowTo Drivetribe
AndyRKett is offline Reply With Quote Quote
Old 04-07-2019   #4
Quote Originally Posted by varesecrazy View Post
LEDs..??
Charlie
no LED's in im afraid, there a filament bulb
Old 04-07-2019   #5
Quote Originally Posted by AndyRKett View Post
Hi Andy,
We've taken all of the fuses out in fuse under the bonnet if that's what you mean, unfortunately for me the lights stay on no matter what we take out. I have a little bit of general knowledge on cars and that was first thing i had done.
Old 04-07-2019   #6
Hi Andy,
Relays are not fuses.
Old 04-07-2019   #7
Ok no problem where are the relays located? Sorry like I said general knowledge so any direction would be great.
Old 04-07-2019   #8
Read the electrical FAQs at top of Grande section
Punto (Mk2/2b) Electrical fault/rear lights Asteroid01 Newbie Central 2 26-05-2019 12:46
(G) Rear top sidelight lens Reiver0112 Ducato 5 06-03-2018 22:49
(T) Sidelight / rear light fuse F3 bluemike165 Multipla 2 24-04-2015 22:51
(T) rear indicator electrical fault robinstall Punto (Mk1) 3 26-11-2005 12:28
