Old 30-03-2019   #1
Brake Drum and Shoes need replacing?
Hello again guys, went to get brake fluid changed this morn, Halfords also carried out a free brake check, said to me that my brake drums needed replacing as well as the rear brake shoes, I will say the brake drums do look very rusty and could most likely do with a change, however theyíve quoted me £400 to do both! I couldnít pay that, I had a little look online about changing them, parts arenít too expensive and it doesnít look too hard, but that could just be different when I come to do it lol, anyone have any more info or help as to what I could do if I do come to fit them.
rundle123 is offline Reply With Quote Quote
Old 30-03-2019   #2
varesecrazy has donated!
Re: Brake Drum and Shoes need replacing?
Thought you said on monday they were ok.?
Rusty drums means nothing..
It is the inside wearing diameter that gets bigger through wear..
What diameter did they measure?
The max. Is cast into the drum
Charlie
Thanks rundle123 thanked for this post
varesecrazy is online now Reply With Quote Quote
Old 30-03-2019   #3
Yeah the front ones are all good as they are the discs, they said they would check the brakes anyhow as thatís what I was booked in for originally
It was just the back ones he mentioned to me that needed replacing, he said the shoes were at the minimum and then said the brake drum was at the max? He said that it would cost more as there is a bearing that comes with the drum also?
Old 30-03-2019   #4
Had similar with our Seicento..
Ended up with a similar bill.. but it was there for an out of time MOT..
So had little option.
You have time to shop around..
Generally the rears take @ 40,000 miles from max to min. What has the car covered?
Old 30-03-2019   #5
Quote Originally Posted by varesecrazy View Post
Ah thatís fair enough! Yeah gonna have to look around last option Iíll do it myself if not!
Iíve owned it from 80k but not sure if they have been changed before then, I doubt it as the last person that had it covered a lot of miles in a few months reckon it will be due a change
Old 01-04-2019   #6
Slovakia
Quote Originally Posted by rundle123 View Post
Are we sure that you need also new bearings? As I saw on YouTube, drum can be removed by unscrewing 2 small screws...it has nothing to do with bearing... I have PuntoIII, maybe EVO is different. Another thing are shoes - to replace them you need to unscrew big center nut which is holding bearing, but bearing can be re-used again I think...
Grande Punto (III) 1.4 8V m.y.2013 (350A1000)
Rado77 is offline Reply With Quote Quote
Old 01-04-2019   #7
Quote Originally Posted by Rado77 View Post
Iím not sure I do really, he told me that if he were to order new drums thereís a bearing or something that comes with it? I had a fiesta thatís wheel bearings were going and they made a huge noise like a bike, but I donít hear that.
Want to do it myself as doesnít seem too difficult just want to know what he meant by the bearing, as nothing on job report about it
Old 01-04-2019   #8
Slovakia
This should be the same I think. He also changed shoes without removing cap/unscrewing center nut/removing bearing.
https://www.ebay.ie/itm/FIAT-PUNTO-E...8AAOSwWkFchO6f
https://www.ebay.ie/itm/Fiat-Punto-E...YAAOSwEbVcGn61
And as you can see, rear bearing is complete separated thing (included with new hub, ABS ring, nut and cap) : https://www.ebay.ie/itm/Fiat-Punto-E...cAAOSwKM9ZqH0k
Thanks AndyRKett, rundle123 thanked for this post
Likes AndyRKett liked this post
Old 01-04-2019   #9
Great video thanks mate, doesnít look too difficult then really, just need to buy a new set of drums and just put them on like the vid says.
Unsure what to do about bearing really if it doesnít need replacing
Old 01-04-2019   #10
Pickwick's Avatar
Pickwick has donated!
There's another useful guide here too if you need it:
https://www.fiatforum.com/grande-pun...rip-clean.html
Although written for the Grande Punto, it should apply equally to the Evo.
Pickwick is offline Reply With Quote Quote
Old 01-04-2019   #11
Will give that one a go! Thanks for the help!
Likes Pickwick liked this post
Old 01-04-2019   #12
The video is from a forum regular..
Thanks AndyRKett thanked for this post
Likes AndyRKett, rundle123 liked this post
Old 01-04-2019   #13
Got it now, brilliant guide will definitely use that one
Old 02-04-2019   #14
Pickwick's Avatar
Charlie
Just in case corrosion has obscured the max diameter on the drum itself, this table from the Grande Punto eLEARN may be of use:
Old 03-04-2019   #15
Yep that was me. Drum brakes are strangely slightly more complicated than discs usually due to all the springs clips and the handbrake, that said once youíve sone one, youíve done them all*
There is no need to replace the bearing if the bearing is ok and usually they are, I did another video once showing the horrible noise made by a dying bearing, you just work around the hub and bearing normally without any issues.
Parts are generally cheap, the process on the grande and evo is very similar to above. My current evo has rear discs so while I intend to change them soon I wonít be making a video thatís helpful to people with drum brakes.... sorry
Maker and voice behind the YouTube channel PuntoHowTo 10k subscribers canít be wrong
And now the owner of a shiny new PuntoHowTo Drivetribe
AndyRKett is offline Reply With Quote Quote
(T) help fitting rear brake shoes and drum starsky Panda (Classic) 15 11-09-2015 07:30
(T) Panda MJ Drum Brake Shoes .How Hard to Fit ? ytareh Panda 25 02-04-2015 15:40
(G) Panda Multijet 2005 Drum Brake Shoes .How Hard to Fit ? ytareh Panda (2012+) 2 14-12-2014 00:07
(T) Rear drum won't fit over shoes csmorris Bravo / Brava 6 31-07-2009 17:18
replacing rear brake shoes on a brava 1.25 sx hoppy FIAT Boo Archives 4 30-08-2005 16:32
