im Axle Specialists
Old 24-03-2019   #1
Brake Fluid Replacement
Can anyone recommend the best way to replace brake fluid? Mine could do with some new fluid or best to take to a garage?
rundle123 is offline Reply With Quote Quote
Old 25-03-2019   #2
varesecrazy has donated!
Quote Originally Posted by rundle123 View Post
What age is it..?
Discs..or drums??
Consider if you want to replace mechanical brake parts..
Do it all together..
Fluid change is not mega.technical.
But requires the bleed nipples to all slacken easily.
Old 25-03-2019   #3
Re: Brake Fluid Replacement
2010, think itís more the front discs, I bought one of these brake fluid checkers and itís coming up that I should change the fluid
Old 25-03-2019   #4
The DOT4 fluid Absorbs Water.
This moisture is BAD in 2 ways:
Tends to make the steel ..and alloy.. parts corrode.. the corrosion makes a rough surface.. which damages the rubber seals
The other issue.. in periods of Heavy ..Prolonged ..braking
The systems work REALLY hard..generating LOTS of heat.. this heat can heat the fluid enough that the water ' boils' and will tesult in loss of braking pressure.
Not ideal 2/3 down a mountain.
At 9 years old.. the fluid will be in a poor state.
Get all the parts together.. spray awkward fittings for a few days before doing the job.. so it has the best chance of things unscrewing.. rather than shearing.
Charlie
Thanks rundle123 thanked for this post
Old 25-03-2019   #5
Okay thank you for the info, do you think I should just take to a garage? Think itís about £40 at my local Halfords, sometimes donít trust my patience lol
Old 25-03-2019   #6
Old 26-03-2019   #7
Combine with front pads for a discount in labour..
Or when rear cylinders need replacing
Old 26-03-2019   #8
Only got the front pads and discs replaced last year! So hopefully just fluid change! Thanks for the help!
(T) Fiat Ducato Brake Fluid Replacement DENNIS SPAIN Ducato 3 08-05-2012 11:17
(T) Brake Fluid Reservoir + Brake Fluid Question oagra Punto (Mk2/2b) 2 21-10-2008 13:13
(T) Brake Fluid Reservoir Replacement MikeSalt Punto (Mk2/2b) 7 23-07-2008 02:00
(T) My Punto needs Brake Fluid, isit a certain one i must get or any brake fluid will do? keepinitcriss Punto (Mk2/2b) 5 02-04-2007 18:30
