I've been the proud owner of an Evo MultiAir 135 for half a year now.
However, after two months the Engine Management Light turned on every now and then. It started off with every once in a while, and has become gradually more frequent. Currently, it turns on 90% of the time. It always starts after I've driven for about half a mile or something, and doesn't start immediately.
Other than a decreased mileage, it drives fine. No noticable lack in power.
I've brought it to the garage twice now. They read the fault codes and said they needed to replace the intake pressure sensor (literally translated from Dutch, not sure if this is the correct English name for it). Sensor replaced, but almost immediately I got the error again. They replaced the sensor again, but to no avail.
They say the fault codes clearly state it's the intake pressure sensor, but as that didn't fix it they say they just have to open up the entire engine to look for the issue, which would at least set me back €1000.
That made my alarm bells ring. Blindly diving into an engine doesn't seem like the smartest solution to me. I asked for the fault codes and am currently trying to figure out what the possible causes could be. As far as I can tell, there's no clear message that it should be the intake pressure sensor, which might confirm my suspicion that the garage hasn't really got a clue what they're doing.
The codes I got were:
So, a few questions:
Hoping someone can help! Love this car but it's giving me quite a headache.
- B1023
- B1013
- P1524
- P1579
- P0106
- P0127
- C1221
- C1286
- These are a lot of fault codes. Is this normal or a sign I should get rid of this car ASAP?
- Can anyone see a common denominator in these codes? I looked them up but can't make a lot of sense of it.
- I read something about loose gas caps giving these errors as well. The closing mechanism in my gas cap has been limp since I got it. Could a loose gas cap cause all of these fault codes?
