Thread Tools
Old 20-12-2018   #1
2010 fiat punto evo not starting
Hi i have a 2010 fiat punto evo active 1.4 the issue is it wont start.It cranks over but does'nt even attempt to start.I have noticed the mileage is flashing could this be something to do with it?
I have done a diagnostic on it and its showing up with no codes
Any ideas before i take it to a garage many thanks.
markybee is offline Reply With Quote Quote
Old 20-12-2018   #2
varesecrazy has donated!
Quote Originally Posted by markybee View Post
Hi.
It'll be basic electrics.. look in the FAQs at top of GRANDE section.. same car under the bonnet
Charlie 07 MJ : 2012 TA
varesecrazy is online now Reply With Quote Quote
Old 20-12-2018   #3
Re: 2010 fiat punto evo not starting
hi i cant seem to find this section? any help would be apprecited thanks.
Old 20-12-2018   #4
Grande punto.
Then yellow boxes..at top of GP section.
Old 20-12-2018   #5
hi,
i tink i found it electrical gremlins?but this only seems to be for random lights coming on and charging problems.
Old 20-12-2018   #6
Bad earth cable is a common failing.
Do that test 1st.
Also check immobiliser light is coming on before key chip is being read.
Old 20-12-2018   #7
Hi, i tried the earth cable trick with the jump leads no differnt,when u put the key in there does'nt seem to be any imobiliser light? i'm guessing this is the orange padlock light?i took the plastic ring off around the ignition and then it came on?but once ring put back on it did'nt? any ideas is this normal or should a light come on?
Old 20-12-2018   #8
Yes.. the padlock light.
Should be on if the keychip isnt in range.
Or for the selftest.
Im not sure if a fault with the immob is looged as P.... engine code
Or U.... body computer
C.... canbus is an option
I am thinking Canbus.. so will need something better than basic OBD.
HAVE you pulled battery power for a few hours..??
Thread Tools
(G) 2010 Fiat Punto Evo GP Heater position knob snapped off :-( jen91 Punto Evo 2 14-01-2013 20:51
2010 Fiat Punto Evo GP 1.4 badgeman Auction Watch 0 29-05-2012 20:04
