Technical punto sport ecu sick
robert foreman
hi ive a 2006 punto 1.4 16 valve sport .ive had the ecu checked and have been told by one tester its the throttle motor control .they cant get the part.another tester said the same
does anyone know a good site were I can get an ecu,fuse box keys etc
thanx: thought I,d add its a bosch ecu
hi,:) at 2006 yours is a Grande, ;)
virtually the same as my 2012.. but a MUCH busier forum section , (y)
I will attempt to get you moved over to there :)
where are you / the car based?
Charlie
Definatly a Grande at that age so not the same 1.4 16 valve engine fitted to the 2012+ puntos which had multiair.
Not sure why you want to change the engine ECU if two people have told you its the throttle motor that's at fault?
The ECU won't diagnosed onboard faults it will suggest that there is a problem with "throttle motor control" if the throttle motor is not doing what is expected.
