Thread Tools
Old 28-07-2018   #1
Normy19 has donated!
Windscreen washer jets
When driving, my washer jets are a lot weaker compared to when Iím stationary. Itís as though the pump has less power when Iím driving so canít force the water out as pressurised?
Not sure whatís going on. Iíve checked the lines, no kinks etc, fuse is all good, jets arenít blocked either.
Anyone ever had a pump go bad, starting to think itís that I know the electrics are said to not be the best, so maybe bad wiring?
Any advice appreciated. Thanks
Normy19 is offline Reply With Quote Quote
Old 28-07-2018   #2
Re: Windscreen washer jets
When you’re driving the wind will blow the washer fluid into the bottom of the windscreen, stationary then the full force of the jets will push the water higher up the screen.
The jets on mine are very strong, it may just be your pump is worn, it’s also worth checking the reservoir as mixing some types of fluid, which can happen over the years, can cause a gunk to build up in and block the pump
Thanks Normy19 thanked for this post
Likes Normy19 liked this post
Maker and voice behind the YouTube channel PuntoHowTo
And now the owner of a shiny new PuntoHowTo Drivetribe
AndyRKett is offline Reply With Quote Quote
Old 28-07-2018   #3
My brother has an Alfa mito and the jets are amazing compared to my Punto, covers the full screen even at 70.
Never thought of that, think Iíll leave my tank to empty and take a look inside. The noise of the pump also changes to a lower tone, as though itís struggling. Maybe itís on itís way out, ah well, another thing to get sorted.
Cheers Andy
Thread Tools
(T) Windscreen washer jets Smeduz Grande Punto 3 04-12-2015 10:47
Windscreen Washer Jets Tommy L FIAT Boo Archives 3 22-02-2008 19:52
(T) GP Windscreen washer jets Ffoxy Punto (Mk2/2b) 1 24-05-2007 12:06
windscreen washer jets paul d FIAT Boo Archives 2 13-07-2005 21:29
Windscreen washer jets Mark FIAT Boo Archives 9 09-03-2005 15:25
