FIAT Auto Specialist Team
Thread Tools
Old 10-07-2018   #1
Question Evo Dualogic Gearbox Trouble
So I haven't posted in a while, but I was hoping for some suggestions regarding an issue I have with the Dualogic Gearbox on my Evo 2011.
It began by 'clacking' or 'clunking' into gear, and being a bit slow to engage. Then it progressed to occasionally dropping out of gear into Neutral when changing up or down (at low speed). I took it to a Fiat dealership who could not diagnose the issue and told me to keep driving until it gets worse.
This week, the gearbox dropped out of gear trying to drop into 1st, and then the Dualogic warning light lit up on the dash, the gearbox refused to enter 1st. I had to push it off a junction, at which point I shut the engine off for about 5 minutes. I attempted to restart the car at which point it carried on as normal. This has happend again since then in exactly the same way.
It is worth noting that it seems to improve when I shift manually, but it does not stop it.
I have it booked in again in a couple of weeks, but was hoping I might be able to get some more advice or suggestions before then.
Some possible causes that I have already come accross on various sites:
  • Automatic Shifter Fluid Low / Leaking
  • Clutch Failing
  • Automatic Shifter Failing
  • Sensor Failing
  • Gearbox Failing
Any thoughts would be greatly appreciated.
Thank you!
Dan Patrick.
Kind Regards,
Daniel Patrick
Fiat Punto Evo 1.4 Dynamic 5d Dualogic (Stop & Start)
danpaddy is offline Reply With Quote Quote
Old 13-07-2018   #2
Re: Evo Dualogic Gearbox Trouble
There are a lot of posts else where on the forum about the dualogic box, so few people come into the evo section it might be worth exploring other parts of the forum for advice.
They only made the evo for 2 years then it changed to the 2012 punto, after which point sales dropped off dramatically, therefore there are considerably less of them about, hence the lack of replies here.
Thanks danpaddy thanked for this post
Maker and voice behind the YouTube channel PuntoHowTo 10k subscribers canít be wrong
And now the owner of a shiny new PuntoHowTo Drivetribe
AndyRKett is offline Reply With Quote Quote
Old 25-07-2018   #3
For anybody who is interested in this issue. I have had it in a dealership today. They said that the gearbox actuator has been infiltrated with water and has corroded (a common issue apparently). They said that refurbishment was unwise, and so a replacement actuator was needed. They quoted £1400 for the job.
Sadly this is my time to say goodbye to my Punto Evo. Time to trade it in for a more reliable car.
Kind Regards,
Daniel Patrick
Old 27-07-2018   #4
Quote Originally Posted by danpaddy View Post
A shame its gone this way. It will undoubtedly end up back on the road when a dealer gets it fixed for a fraction of what you'd have to pay.
Just be aware if you're thinking of buying another car with an automatic gear box, there are a lot of unreliable ones about now, so do your research before you buy.
Thread Tools
(T) Dualogic Gearbox Bodatron Grande Punto 65 08-02-2015 14:43
(T) Punto Evo 2010 Dualogic - Gearbox disengages from engine Mozes Punto Evo 5 03-09-2014 10:09
New Punto Evo Dualogic - Scary on hills/slopes - SS feature papillon Newbie Central 0 31-07-2011 22:47
(G) Punto evo dualogic Mrsam21 Punto Evo 14 04-03-2011 11:38
(T) Dualogic gearbox knersus Punto (Mk2/2b) 5 05-03-2008 19:53
