im Axle Specialists
Thread Tools
Old 12-04-2017   #1
Estonia
Change engine oil error
Hello guys
I bought my car (Fiat Punto Evo 2010 multijet 1.3 diesel 62kw) 1,5 years ago. The mileage was about 122 000 km or smth.
Since the 62 kw was a bit sad and I was afraid of DPF filter caused problems in future i got it removed and engine chiped to 80kw. I had no problems for 1,5 years. Changed oil twice in this time (130 000 and 140 000) and when the service interval (30 000) got full turned on the oil indicator and appared the message "change engile oil". Since it was time for regular maintanance i brought it to service.
They did the maintanance but weren't able to make the message "change engine oil" and red indicator light dissapare. They asked if the DPF filter is removed and claimed that it might be the reason they can't reset it/make the warnings dissapare.
The guy who chiped the engine and turbo and removed DPF said he didn't touch anything service related, tried to remove the warning but weren't able to with his universal tool and program.
http://www.gendan.co.uk/article_6.ht...punto_evo_2010
suggests to use MultiECUScan Diagnostic Package for service reset.
btw car works perfectly fine just will have problems in regular check next year :/
Any ideas? I really don't want to buy the new filter and go back on 62 kw.
Skankpoom is offline Reply With Quote Quote
Old 12-04-2017   #2
Trader Rating: 1
portland_bill has donated!
Re: Change engine oil error
As your link suggests, MES is the way to go.
You need to sort this soon. There have been stories on here where service reset has been ignored and ECU has shut down into limp mode, then costing lots of money for a dealer to reset.
MES will tell it service is done, all is then happy. Dealer will make a fuss if DPF not there.
MES €50, plus the cables and ELM interface. Bargain.
13 years motor trade, 16 years motor industry. 14 years Driving Instructor & 7 years Fleet Trainer
Panda Alessi
portland_bill is offline Reply With Quote Quote
Old 12-04-2017   #3
Moderator
g8rpi's Avatar
g8rpi has donated!
Quote Originally Posted by portland_bill View Post
A suitable lead is
http://www.ebay.co.uk/itm/271275445368 (£15) I've used this seller
You also need adaptor 3 (yellow) such as http://www.ebay.co.uk/itm/152487652423? to do the service reset. However in this case it may be the engine ECU oil change counter that needs to be reset. This is only on the DPF models and is a separate function to the service interval reset.
Robert G8RPI.
g8rpi is offline Reply With Quote Quote
Old 14-04-2017   #4
Estonia
Ty for feedback. I will try to find someone who has the MES and adaptor and if i wont i'll order the ones g8rip suggested.
Will let u know of the results
Old 19-04-2017   #5
Estonia
Quote Originally Posted by g8rpi View Post
A suitable lead is
Robert G8RPI.
Well.. I found a guy with software but he didn't manage to fix it.
As u said in this case might be the engine ECU oil change counter that needs to be reset. So, is it actually possible that the problem is associated with DPF filter software somehow after all and since the DPF and that part of software is remaped the computer doesn't access to this part of software and I can't reset it in this condition?
If it is so, the only option is to remap the software to factory conditions and reinstall the dpf filter?
Or maybe there are any other options (i noticed that there are many tuning parts available on ebay, maybe installing some of these instead could help?)
Any optional ideas?
Don't want the LIMP mode but i really need it for daily use
Old 16-05-2017   #6
Estonia
MES doesn't connect to engine modules for some reason (probably the reason is that these are over written by the guy who removed DPF). Yet no problem with the other modules.
Yet there might be another option..
MES, Service, Set number of service coupons module says: "This function allows you to set the number of service coupons. It is set to 9 at factory, and the number decreases at each Service Interval Reset. When the number of service coupons reaches 0 the "Service due" functionality on the dashboard is disabled.
You can enable the "Service due" functionality again by setting a value greater than 0.
You can disable the "Service due" functionality by setting a value of 0."
Do you guys think it could work out if I change the Service due to 0? In this case the light should stop blinking and the information from display should dissapare, since the functionality should be disabled by that? Or am I wrong in here? Could that change have any other consequences?
Or what if I change the service interval value to lot higher like 100 000 or smth?
I'm a bit afraid to mess with the ECU since I have no previous experience.
Old 16-05-2017   #7
Moderator
g8rpi's Avatar
g8rpi has donated!
Quote Originally Posted by Skankpoom View Post
There is no harm in changing the service coupons to zero, but I don't think it will help. You need to reset the oil degradation setting in the engine ECU. As said before this is different to the service reset (which is in the body ECU) Normally the engine ECU is the easiest ECU to connect to. With MES and an ELM interface you should NOT use the yellow adaptor to talk to the engine ECU. If you were using the yellow adaptor before, try without it and see if you can connect to the engine ECU. If not you need to talk to whoever "chipped" the ECU to find out what they did and why it won't work.
Robert G8RPI.
Old 24-05-2017   #8
Estonia
The way it got done:
Installed Multiecuscan registered 3.0 or smth
The operation I did:
Fiat Punto Evo 1.3 Multijet 16V — Control module: Marelli 8DF CF5/EOBD Diesel Injection (1.3) — System: Engine — Connect — Adjustments — Reset self-learnt functions — Execute. Key off for 40 sec and done.
The comment/help window doesn’t explain that this option also resets the engine oil counter yet it did.
There is also an option “oil change (only for version with DPF)” I expected that to be the key to success and I executed this option but the warning light didn't dissapare.
It was my first time operating in ECU and I'm really noob in this but maybe this knowledge will help someone other noob in the future.
Ty for support to everyone who found time to replay 😊
Dislikes dombooth, Davren disliked this post
Old 25-05-2017   #9
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
The way it got done: Installed Multiecuscan registered 3.0 or smth (cracked, saved 50 eur )
@yani the author of Multiecuscan is a member of this forum. We do not condone the theft of, or illegal use of his software.
Thanks varesecrazy thanked for this post
Likes portland_bill, g8rpi, jackwhoo liked this post
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW)
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 25-05-2017   #10
Multiecuscan is amazing and you can try it for free which is more amazing. Don't spoil it for others by giving criminals your money for illegal versions.
Likes g8rpi liked this post
jackwhoo is offline Reply With Quote Quote
Old 26-05-2017   #11
Trader Rating: 1
If we don't pay for MES, it will cease to exist. Then we're all in the poo.
Thanks Zeewulf thanked for this post
Likes Zeewulf, g8rpi, jackwhoo liked this post
Panda Alessi
Thread Tools
(T) change engine oil message and red oil light flashing on the dash... grungdog23 500 26 1 Week Ago 19:14
(T) Engine Oil change indicator wont stop after oil change! arbervehbi Croma 8 17-09-2015 20:34
(T) Engine run in - oil & oil filter change Gregi Abarth 500 22 18-04-2013 21:56
(T) Need some help with oil change and engine flush etc... Mr Cousins Stilo 12 04-02-2011 23:06
(T) engine oil change fixitagaintmw Stilo 3 28-03-2009 21:49
