I have just purchased a 2011 Fiat Punto Evo 1.4 Dynamic (5d Dualogic) with S&S, the car seems to be running okay, temperature gauge is normal and the engine sounds fine. I noticed after I bought it that the heater wasn't working (fan was blowing but there was not heat). I sent it to the garage who blasted it out with water, and then it seemed to work fine. Then this morning I started it up and pulled off, as I did I heard a sound coming from the passenger side (seems low down like it's by the bottom of the door) which sounds like running water. It seems to happen when accelerating from a stop or in low gears, and not when braking. Any idea what it could be caused by, and what the fox may be?
Thanks,
Dan.
Thanks,
Dan.
