![]() | #1 | ||
Posts: 25 Thanks: 0 Trader Rating: 0 ![]() | 1.6 mjet mes results - problem Ok so i did some tests. My turbo is overload pressure or sensor in manifold is wrong becouse mbar is top high but position of turbo is ok. I did egr test too and i think its fine. But if somebody can tell me that my turbo is going to change or maybe sensor is wrong. Turbo is sometimes loud and make somethink like blow off but i have pipercross intake. Put results in csv evening. Also my boost control on idle is 62% when most of you have 75. http://www43.zippyshare.com/v/xvO5pPQa/file.html http://www43.zippyshare.com/v/JLKrMyBr/file.html
![]() | #2 | ||
Posts: 26,571 Thanks: 1024 Trader Rating: 0 ![]() | Re: 1.6 mjet mes results - problem Ok so i did some tests. My turbo is overload pressure or sensor in manifold is wrong becouse mbar is top high but position of turbo is ok. I did egr test too and i think its fine. But if somebody can tell me that my turbo is going to change or maybe sensor is wrong. Turbo is sometimes loud and make somethink like blow off but i have pipercross intake. Put results in csv evening. Also my boost control on idle is 62% when most of you have 75. http://www43.zippyshare.com/v/xvO5pPQa/file.html http://www43.zippyshare.com/v/JLKrMyBr/file.html ![]() can we have some background to this..?? happy to try and help - but need to understand; 1, what you've found / done, 2, what you need / are asking, Charlie
![]() | #3 | ||
Posts: 25 Thanks: 0 Trader Rating: 0 ![]() | 1.6 mjet mes results - problem Hi, Yeap my english is not so good ![]()
![]() | #4 | ||
Posts: 25 Thanks: 0 Trader Rating: 0 ![]() | Re: 1.6 mjet mes results - problem So i did simple MAF test. After unplug connector car runs ok but with 20% less power. Turbo wasn't make chatter noise and "blow off". If anybody can tell me why turbo make noises like that? In first post i write some MAF values in diffrent conditions. Thanks in advance.
![]() | #5 | ||
Posts: 25 Thanks: 0 Trader Rating: 0 ![]() | Re: 1.6 mjet mes results - problem Hello Guys, I have one question. What readings from boost control solenoid do you have on idle? Mine shows something about 62%. Many of you in other treads have this values on idle closer to 75%. Is there anyone who has 1.6 multijet or 2.0 multijet and could check VNT% on his car? It will be much appreciated Many thanks in advance Pat
![]() | whity | Stilo | 3 | 09-10-2016 15:29 |
![]() | antonyriozzi | Grande Punto | 2 | 19-06-2013 17:50 |
![]() | darthbane666 | Grande Punto | 15 | 20-01-2012 14:44 |
![]() | Ricardo sousa | Panda | 1 | 04-01-2010 10:25 |
![]() | ian grant | Panda | 3 | 16-11-2008 07:56 |
