Thread Tools
Old 12-11-2016   #46
Re: Slow mod ?
So, reset codes and observ that is shows again. You can make photo from alfaobd with turbo position and turbo boost valve. My turbo boost valve shows 61% and 0,62 mm turbo. Curious what yours?
puntoevodiesel is offline Reply With Quote Quote
Old 09-12-2016   #47
France
Re: Slow mod ?
Bought a new EGR, but joint wasn't with it so I added one on the order, but it's not one that can do...
I don't really know where to get one that fits correctly or if there should be one in the first place
diameter 41mm en 80mm between screw hole, tho a simple 41 circle joint could do
Evo63 is offline Reply With Quote Quote
Old 08-03-2017   #48
France
Re: Slow mod ?
After I finally had all needed to replace the EGR I started but the screw got ****ed... So I didn't proceed as I didn't have any backup plan
Finally got someone to help me and replace it
There was once again some liquid going out from it
Probably coolant ?
I was told there is some kind or cooling system to lower gaz temp before recycling them, and the leak should be coming from it
Something like this ?
Price 144€
Got no idea yet if slow mod of P010F error still come up, will have to check on this in coming weeks
If the car run smooth, is it bad to leave it this way ? Must I replace that unit ? Saw some pretty high price with mounting done, I guess a lot needs to be dismounted to replace it
Thread Tools
(T) Slow Acceleration Fault....But Not THAT slow! Simonf1973 Stilo 2 03-09-2010 22:45
(G) Legal vs Country (to mod or not to mod) RuiG Cinquecento / Seicento 6 06-06-2008 23:07
SLOW SLOW SLOW ben Latest News 99 30-07-2004 22:22
Slow, slow, quick, quick, slow Patrick FIAT Boo Archives 3 13-10-2002 18:11
