With
MES with actuators
Well, I thought about it, and also DPF, but here in France this year they are collecting data, and in about 2 years, they will make it harder to pass some technical control we do every 2 year, and people that removed this, could have serious problem so I'm not really sure it's worth it, even if everyone says it's the best option
And also when they remove EGR DPF they can also reprog the car to ~150hp and 380Nm.
I also noticed this :
1
2
Don't know if it could be related but seems it was repaired somehow...
Thing is, I don't know where my lack of power come from, is the car just like that, nothing below 2000rpm ?
I mean with something like
that on a road going up, on 2nd gear and ~25km/h, it doesn't catch up that fast, but another car with 90hp did a lot better (but maybe I was going faster with 15"...), I mean, in this conditions, it seems my old 50hp ibiza is the same, at least until it reaches 2000rpm
Then also with no gear on, on my ibiza and other car I tried, when accelerating, RPM would go up really fast, here is seems to be regulated or smt, thought it could be ASR but think it's the same when it's off, so I don't know, there isn't any resistance but it doesn't seem free to go fast
Not sure I explain it correctly but hope you'll understand and can tell me how it is for you puntoevodiesel
About MAF sensor, I'm skeptical, I mean, I wanted to clean it, but then discovered it is only about 1 year old, from manufacturing date, and even less on the car probably so I didn't clean it, tho there was nothing to clean, I just put it back, then yes maybe it's faulty, I don't know much sadly
Desired EGR Position : Target EGR position value as calculated by the engine control unit based on the readings of various sensors.
"Actual EGR position is the position assumed by the EGR, compared to the desired EGR position. The 2 parameters tend to follow each other, i.e. they should have similar values."
I had both MAF and EGR position fault code
After re reading some guide about How-to Fix the EGR on a 1.9JTD.pdf, it says "You’ll find the end of the solenoid is either stuck fast in the body, or requires a fair bit of force to move in and out. It’s on a spring so should easily pop in and out. If it doesn’t you’ll know at this point that you have found a problematic EGR!" when I dissemble it was out, I pushed in, didn't have to force at all, but it didn't come back
