A ajhudson New member Joined Aug 4, 2016 Messages 2 Points 1 Aug 4, 2016 #1 The ABS warning light on my Punto Evo is on. No codes appear when checked with a code scanner. Sensors appear in tact. Brake pads have been changed. Has anyone else had this problem or have any ideas how to fix it? Thanks
V varesecrazy Patron member Written 10+ guides Joined Apr 27, 2011 Messages 34,956 Points 7,826 Location Near the M4 Aug 4, 2016 #2 ajhudson said: The ABS warning light on my Punto Evo is on. No codes appear when checked with a code scanner. Sensors appear in tact. Brake pads have been changed. Has anyone else had this problem or have any ideas how to fix it? Thanks Click to expand... Hi, and welcome, does your scanner do body computer..? lots just do engine, dips in power can cause this - suspect battery / alternator output., etc. I'll happily read codes if you are local, Charlie - Oxford
g8rpi Moderator Staff member Parked in the garage Written a guide Uploaded a resource/download Joined Nov 11, 2013 Messages 4,599 Points 1,167 Location Cambridge Aug 4, 2016 #3 varesecrazy said: Hi, and welcome, does your scanner do body computer..? lots just do engine, dips in power can cause this - suspect battery / alternator output., etc. I'll happily read codes if you are local, Charlie - Oxford Click to expand... Ditto, I can read codes if you are near Cambridge.
portland_bill Patron member Joined Feb 22, 2004 Messages 9,915 Points 2,854 Location Faringdon, Oxfordshire UK Aug 4, 2016 #4 ajhudson said: The ABS warning light on my Punto Evo is on. No codes appear when checked with a code scanner. Sensors appear in tact. Brake pads have been changed. Has anyone else had this problem or have any ideas how to fix it? Thanks Click to expand... Did the problem occur immediately after the brake pads change? Sensor damaged during pad change?
OP OP A ajhudson New member Joined Aug 4, 2016 Messages 2 Points 1 Aug 4, 2016 #5 portland_bill said: Did the problem occur immediately after the brake pads change? Sensor damaged during pad change? Click to expand... Problem occurred before brake pad change. The light has been on for a while & I had ignored it because it didn't bother me. I want to sell it now so will need it fixed first.
V varesecrazy Patron member Written 10+ guides Joined Apr 27, 2011 Messages 34,956 Points 7,826 Location Near the M4 Aug 5, 2016 #6 ajhudson said: Problem occurred before brake pad change. The light has been on for a while & I had ignored it because it didn't bother me. I want to sell it now so will need it fixed first. Click to expand... so where is the car based..?? as somebody local to you can probably offer a cost-effective method of at least diagnosing the issue
