Old 25-11-2015   #1
ses6jwg has donated!
1.4 Multiair turbo smoking
Does any body elses 1.4 multiair turbo smoke quite heavily when first started up? It's kind of a white/ grey whispey smoke that rises up rather than pluming.
It seems to go away when the car is warmed up, except when reversing when it chucks it out again?
I do have a TMC motorsport box fitted which has made it a bit worse.
I don't seem to be using much oil. Have only topped up slightly since I bought the car in March. I have had to top the coolant up slightly (it dropped from MAX to MIN level) which does concern me... I have a slight yellow film under the oil cap sometimes but the car is sat sometimes for a week without any use. The coolant looks the right colour. It also starts first time without any problems and doesn't misfire, MPG looks about right and power isn't down.
Is it worth getting the head tested?
ses6jwg is offline Reply With Quote Quote
Old 25-11-2015   #2
varesecrazy has donated!
Quote Originally Posted by ses6jwg View Post
Possibly..
I would remove the spark plugs looking to see if 1 is sooty/ oily.
Charlie .Oxford
Old 26-11-2015   #3
Re: 1.4 Multiair turbo smoking
Taken tonight. Car has been sat unused since Saturday. Ambient temp 2-11 degrees c.
Started with no trouble. No smoke until I poked the accelerator. Then it smoked wispy smoke. Quite heavily until up to temp. Hand over exhaust got very wet. Liquid looked clear. Coolant looks the correct colour.
Will try and get a video
Old 26-11-2015   #4
Ok. So I went for a drive tonight. Ambient temp is about 10 degrees. Bit of smoking around town until up to temp. Nothing at motorway speeds.
Stopped to idle for a bit and no smoke out of exhaust at idle and temp stays middle. No fan kicking in.
Revved it a bit at idle when up to temp and no smoke.
I'm just going to monitor it and see how things go.
Old 02-07-2018   #5
Did you ever get this sorted? My Evo started doing the same. Thanks Steve
May4943 is offline Reply With Quote Quote
1.4L MultiAir Turbo Specs Thippid Tech Talk 3 02-02-2015 17:19
(Tu) Multiair Turbo Power loss alex evo Punto Evo 8 25-10-2014 00:07
(G) Correct Oil For Multiair Turbo col-blue Punto Evo 8 02-07-2013 19:15
(G) 1.6 MJ or 1.4 turbo Multiair? The Free(welsh)man Punto Evo 4 06-01-2012 14:20
(T) Some 1,4 MultiAir Turbo data Sev Bravo 4 12-05-2010 21:21
