Ned Flanders
- Apr 15, 2005
- 77
- 22
Hi folks,
I just purchased a used Punto Evo 1.4 GP (8v) and within a day of owning it I noticed that there is some weird issue with the lights. when I have the headlights on for some reason the driver side fog light will come on intermittently. Seems to happen as soon as I engage reverse and appears to stay on. If I switch off the ignition and back on again then the light will be off but within minutes it's usually back on again. Any idea why this is happening? I understand I'll need to check the wiring but as I'm a bit of a novice I'm looking for some guidance on most likely cause. I was thinking about upgrading all the headlights anyway to xenon so maybe I should just do the whole thing at once? Thanks for the help!
