Technical Installing subwopfer, help on where to run cables
Hi so i have a sub and amp and all cables, my first challenge is to run the power cable. I don't know where the easiest place to run the cable through to the underside of the glovebox would be. The hole for all the other wires look really hard to get at and very hard to run any more things through. Could anyone help me out? possibly with the whole process!!
Thank you
I ran my sub cable in the wing and in a grommet by the front door ImageUploadedByFIAT Forum1433079540.248281.jpgImageUploadedByFIAT Forum1433079589.116717.jpg
Thank you! Run it through now!
Next challenge for me getting the radio out... I don't have the special pins but I do have 4 long thin hex-keys that if I put in seem to click into place.
Am I right in saying you then pull them outward and toward you and it should release the unit??
I have had no luck.. What did you use? Is there a certain set of pins to get?
Yer it is just go to local halfords they shud have some i wudnt risk the hex key trick
