Old 08-04-2015   #1
Greece
Punto Evo Big Turbo project
So,after trying every single thing in terms of tuning with stock turbo on Punto Evo multiair i found a TD04-15T and decided to give this little creature life.
So,it was nothing to worry about,if your engineer is good enough it makes it with really low cost.
So this is the turbine
This is with the turbine firstly fitted in the engine.You have to open the head of the turbo and turn it around so the houses and pipes will fit directly
And the final results:
Any question can be answered
Likes evosportingfan, alex evo liked this post
TheAlfacode is offline Reply With Quote Quote
Old 09-04-2015   #2
Romania
Re: Punto Evo Big Turbo project
what about the exhaust manifold?
is it custom?
aurick86 is offline Reply With Quote Quote
Old 09-04-2015   #3
Greece
stock and only a flange made for the turbo to fit.
Old 12-04-2015   #4
hi buddy is the turbo u used the same as the abarth? have u had it remapped yet, if so wot power is the car running? my understanding was that the injectors would need upgrading to suit. also wot was the overall cost and is the difference worth it?
many thanks..
evosportingfan is offline Reply With Quote Quote
Old 13-04-2015   #5
Greece
Hi guys.
Turbine is Mitsubishi td04 and you find it on saab 2000cc turbo, Subaru impreza etc.
You will need oil and water pipes for the turbine, a blow off valve, of course a good remmap, a mechanical or electronic boost controller,and a handmade flange for the turbine to fit the stock manifold.No high cost, affordable for the power it gives.
I'm running 1,4 bar at rev limiter and i am 270bhp.I will post dyno these days.
Old 23-04-2015   #6
Netherlands
270 on this tiny fiat engine are you mad?
Kingpin is offline Reply With Quote Quote
Old 27-04-2015   #7
Greece
Currently running at 240bhp gonna post dyno
Likes alex evo, varesecrazy liked this post
Old 15-05-2015   #8
Quote Originally Posted by TheAlfacode View Post
When you say you need a boost comtroller i have a forge aculator would that be ok
kermit24 is offline Reply With Quote Quote
Old 16-05-2015   #9
Greece
Boost actuator or wastegate is the thing on top of the turbine.By turning it back and forth you are tuning your pressure.With a mechanical boost controller you can tune up or down the boost set by the wastegate (depends on what is max and min in the set boost in wastegate) The good thing of boost controller is that gives you overboost with better results than programming via n75 valve.
Electronic boost controller is much more expensive and the best by far cause it can hold really stable boost , tune your overboost and has some other interesting settings too.
Old 16-05-2015   #10
Greece
Here's a video of me running at 1 bar and only. (approx 190 bhp with second person on board and unfinished ecu tuning)
https://www.facebook.com/piperman.pi...type=3&theater
Old 16-05-2015   #11
Germany
Well done. We converted an Multi-air to BorgWarner EFR6258. Result, 250PS.
GTD is offline Reply With Quote Quote
(T) Turbo Punto evo startek2 Punto Evo 0 07-08-2014 14:50
(T) Karolis Punto 75 Turbo project Karolis Punto (Mk1) 101 14-01-2014 18:34
(G) punto gt turbo project puntogt1 Punto (Mk1) 20 01-12-2009 23:56
Project EVO! Ben R Members Motors 18 03-11-2005 19:17
