Old 29-01-2015   #1
Punto Evo GP ABS, ESP And Hill hold light on??
My Son has a 2011 Evo GP. The abs, hill hold and esp lights have come on and also speedo drops off occasionally? Have changed n/s/f abs sensor as scanner said no signal, lights would not clear. Changed brake pedal switch and all lights appeared to go off. After about half an hour of driving lights have now come back on!! Any ideas would be appreciated???
speedy 500 is offline Reply With Quote Quote
Old 29-01-2015   #2
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Re: Punto Evo GP ABS, ESP And Hill hold light on??
Check wiring between abs multi plug and wheel sensor for high resistance
Massive gash
Just a little touch up
Old 29-01-2015   #3
Thanks for that, have checked and all appears ok?? Initially there was no reading on n/s/f but replaced sensor and still have same issue. Have also checked abs unit multi plug and totally dry??
Old 31-01-2015   #4
Moderator
Andy Monty's Avatar
Check the integrity of the wiring between the abs multiplug and the ns abs sensor water gets into the plug and wicks up the copper wire rotting it behind the PVC insulation
Massive gash
Old 01-02-2015   #5
Romania
1. reset the clutch and brake switches:
-untwist from holder
-remove wire connectors
-grab plunger with pliers and pull it out.
-refit.
check if light goes off after a few on/off cycles of the key.
2. get multiecuscan and read the errors.
aurick86 is offline Reply With Quote Quote
(T) abs, esp, & hill holder failure Jonjo Grande Punto 33 13-12-2017 18:28
(T) Dualogic, hill hold & how to tell if ESP is fitted? GoGas 500 30 21-05-2013 10:52
(G) ABS, ASR + Hill hold adam1987 Grande Punto 10 19-12-2010 12:47
(T) Abs, ESP, Hill Holder Failure - Punto 1.8 HGT nandojem Punto (Mk2/2b) 3 27-10-2010 19:17
