S spoonfoot New member Joined Jan 22, 2015 Messages 3 Points 2 Jan 24, 2015 #1 When I operate rear screen washer water leaks onto parcel shelf. Is there any way I can access the tubing that's attached to the washer jet,as I think that's where it may be leaking.Any help appreciated.
V varesecrazy Patron member Written 10+ guides Joined Apr 27, 2011 Messages 34,955 Points 7,825 Location Near the M4 Jan 24, 2015 #2 Hi, and welcome to FF, have a look in GP section, as the Punto has been here for 8 years now, somebody will have asked this before (SEARCH is great in "advanced") , Charlie - Oxford
OP OP S spoonfoot New member Joined Jan 22, 2015 Messages 3 Points 2 Apr 12, 2015 #3 Thanks for all the advice,finally got around to doing this. Turned out the feed tube had pulled off the spray nozzle.Thanks again
V varesecrazy Patron member Written 10+ guides Joined Apr 27, 2011 Messages 34,955 Points 7,825 Location Near the M4 Jul 31, 2022 #4 Stumbled across this again.. Others have found a joint can fail in the rear footwell... So a few push.fit connectors on 10+ year old hoses looking to break free ... My suspicion is that in cold weather the spray noddle can freeze... putting extra stress on the hose joints when the pump is run
