FIAT Auto Specialist Team
Old 05-12-2014   #1
DazEvo has donated!
"twang" sound when turning the steering wheel
Literally over night this problem has risen.
When turning the steering wheel at low speed/stationary there is a "twang" sound and I can feel the jolt through my pedals.
The springs have been checked, only other thing I'm guessing is the top mounts? Anyone else had this problem..
The car has only done 29000 miles... why have these started to wear already?
Owner of a 2010 Punto Evo Dynamic - 1.4 8v // Modifications: Tinted windows, 17inch Alloy Wheels, Sprayed breaks, Lights converted to LED etc.
DazEvo is offline Reply With Quote Quote
Old 05-12-2014   #2
varesecrazy has donated!
Re: "twang" sound when turning the steering wheel
sounds like tight bearings in the top mount,
they no longer swivel freely..,
then move with a surge..hence the spring going doinggg..!!
mileage has nothing to do with it,
look in the GP section for more info,
Charlie - 2013 punto
Old 06-12-2014   #3
DazEvo has donated!
Quote Originally Posted by varesecrazy View Post
okay is the only option for it to be replaced? and what needs replacing exactly, the top mount of the bearings?
Old 06-12-2014   #4
Quote Originally Posted by DazEvo View Post
you could TRY and lubricate them..,
Charlie
Old 06-12-2014   #5
Moderator
Andy Monty's Avatar
Andy Monty has donated!
See the grande punto guides section both replacement and strip and service are detail ed in there
https://www.fiatforum.com/grande-pun...placement.html
Old 06-12-2014   #6
Quote Originally Posted by Andy Monty View Post
thanks, advised they looked there yesterday
Old 06-12-2014   #7
Moderator
Andy Monty's Avatar
In the guides section rather than the gp forum.. Thought I might as well give daz a direct link to my guide
I did mine again last weekend went none fiat this time its been almost a yearly job on the evo and my last gp
Worst bit is wiper arm removal I cracked my windscreen a few years ago when the puller twanged off :-(
Massive gash
Just a little touch up
Old 08-12-2014   #8
DazEvo has donated!
Charlie
What part do I lubricate? Sorry im a bit naive... is what your saying as simple as spraying wd40 onto the bearing haha? :P
Old 09-12-2014   #9
Moderator
Andy Monty's Avatar
see the guide
wd-40 will just make the issue worse (as it thins the grease) and you will struggle to get it into the bearings.....
it needs stripping...
Massive gash
Old 09-12-2014   #10
DazEvo has donated!
see the guide
hmm the effort required to lubricate it, may as well replace them?
Likes Andy Monty, Mkala liked this post
Old 09-12-2014   #11
Moderator
Andy Monty's Avatar
yes i just gave people both options if you catch them early or do it as preventative maintenance say when replacing a shocker or broken spring for example but if they are making a racket its best to replace them both (one each side) as the rubber bush wears against the car body
Massive gash
(T) Steering wheel wrong "angle" Md2012 Punto (Mk2/2b) 8 31-03-2014 20:07
(T) "ClickClick" wheel sound - steering box or not B0yCk Stilo 16 07-08-2011 13:53
(T) Steering "thud/clunk/click" felt through steering wheel. tezza473 Grande Punto 6 20-06-2010 18:35
(T) "mice" and steering sound mafia11 Punto (Mk2/2b) 1 07-09-2008 18:44
(G) NEWS - Grande Punto Wins "Golden Steering Wheel" Steven Grande Punto 4 10-11-2005 16:15
