Old 06-11-2014   #16
DazEvo has donated!
Re: Canbus error reg plate light
Correct.
I have led 501s in my side lights at the front of the car, how would the resistor work there? Because the bulb holder clips inside the headlight and is not the same as the number plate connector?
Owner of a 2010 Punto Evo Dynamic - 1.4 8v // Modifications: Tinted windows, 17inch Alloy Wheels, Sprayed breaks, Lights converted to LED etc.
DazEvo is offline Reply With Quote Quote
Old 07-11-2014   #17
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
Quote Originally Posted by DazEvo View Post
On my resistors there was a rubber rib, so you just pushed it into place and it held properly. Might need some inginurity to make them fit, but shouldn't be too difficult.
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
1993 Classic Panda Selecta, 1989 Panda 750L,
2015 Kia Soul EV, 2009 Panda Eleganza & 2005 Panda Climbing 4x4 (LPG)
Most Easterly Pandas is offline Reply With Quote Quote
Old 07-11-2014   #18
DazEvo has donated!
ah ok. I got given these resistors with the front sidelights that might be better, seems they are a little complicated though... is soldering required? have a look
the diagram:
Old 07-11-2014   #19
Trader Rating: 2
the diagram:
Yes you'll need to solder or skotch lock them into place. I'd bin them and use the inline ones for ease and reversibility.
Old 07-11-2014   #20
DazEvo has donated!
thats what i was thinking, way too much modding for my liking.
Old 07-11-2014   #21
DazEvo has donated!
Has anyone replaced their reversing light bulb to a brighter one? I feel sometimes I cant see a damn thing when reversing... and that light is there to warn people as well as provide us with some lighting at night :/
Old 13-11-2014   #22
DazEvo has donated!
got my resistors, no rubber rib or any secure mounting at all really :/ I suppose its ok for the number plate where gravity will keep the LED in the plastic housing.. however as for my parking lights it just sits in the "tunnel".. whereas the original fiat fitment clicks into place... luckily i only ordered one pair so ill try and find some with rubber fitments.
The fitment for the number plate bulb is basically a turn and lock mechanism... im guessing thats the same as your bravo?
Also I cant really see what the resistors are touching, and have been warned they get hot.. any risk to the car? Im guessing they are resting on the inside of the bumper?
Original parking lights fitment (clips in)
Resistor fitment:
Old 13-11-2014   #23
Trader Rating: 2
Rear ones on the Bravo being partly external had a lot of air circulating around them, fronts being in a headlight enclosure which has lots of heat from the bulbs anyway didn't cause me any concern, and didn't have issues over the 24 months I had the car.
For the front might be worth putting some insulation tape around the bulb holder to give it a more snug fit when putting it in place (I can't remember if I had to do this or not), but might be worth improvising
Old 13-11-2014   #24
DazEvo has donated!
Ok cool thanks for the help. If I cant find any with rubber ribs Ill just use a bit of tape or blu tac :P
Old 17-11-2014   #25
DazEvo has donated!
Fitted my dad's GP with the osram night breakers. Cant really judge the viewing distance until its pitch black and were on a dark road.. one thing I will say though is that they are not as white as my ones from Ebay which were 15 reduced to 8. Im guessing the 100w also contributes to a whiter light?
Old 17-11-2014   #26
Trader Rating: 2
Not always the reason behind it, and don't forget 100watt bulbs are illegal to use on the road in the UK and are asking for costly problems later on with the car.
Old 18-11-2014   #27
DazEvo has donated!
yeh i realised they are illegal... what problems can they present with the car being 100w?
Old 18-11-2014   #28
Trader Rating: 2
Can cause the wiring to potentially burn out and cause a fire due to the additional loading, and if you're lucky it might only melt the chrome reflection off of the reflector resulting in light output getting worse and eventually having to change the headlamp units
Old 18-11-2014   #29
DazEvo has donated!
jesus christ lol... ill be changing them then
Old 18-11-2014   #30
Trader Rating: 2
If I remember when I get home I'll post a pick of damage I noticed on a GP headlight reflector at Stanford Hall this year, it wasn't a pretty site.
(T) Aftermarket Bluetooth Kit, CANBUS Error ? ShR33k Idea 1 27-02-2013 21:42
(S) canbus error free still get warning scargi Grande Punto 23 08-01-2013 13:42
(S) LED Canbus error free Davesport130 Grande Punto 3 17-07-2011 23:20
