Sounds like the accelerometer that measures sideways acceleration/"g force" has packed up (or rather the CAN node that it sits in has got issues).
Yeah it was the ABS I connected it, shows at the bottom of the picture, got mixed up
Where would I find the accelerometer or the can node?
I read also could be the YAW sensor?
They're possibly the same thing. I always thought that yaw sensors were gyros but I guess they could be an acclerometer too. I would have thought they'd all be packaged together in the ESP "can" that's under the bonnet.
Did you manage to find the yaw sensor ?
It has to be bolted on chassis, possibly the region you mentioned. But not sure.
Don't know any doc for the Evo. Perhaps can I find something on Grande Punto if you want.
Yes if you don't mine please
With pleasure
After some search, I found on the Grande Punto the YAW sensor is behind the gear stick, under the cover of handbrake. I can't verify this on my car, because I don't have ESP.
To remove the handbrake cover, you have to pull on it. I start with the rear part, it's more easy to take it. Never removed it completely, not necessary to set the handbrake tensioner.
Procedure :
Hope this help
With pleasure
Procedure :
Hope this help
I can't seem to figure out how to remove the hand brake surround, is it screwed in somewhere?
No screw in my cars.
Official way (if it is more clear for you, for me not really... I pull and shake the cover, more at rear, until it comes) :
Just pull off
I took a pic for you :
Hope this helps, keep us informed
