Old 30-06-2014   #16
Re: Error With Punto Evo U1715
Quote Originally Posted by varesecrazy View Post
should be.. remove the cup holder / bin at rear..!! ; - }
How do I pull the cup holder out? Click image for larger version
Name:	ImageUploadedByFIAT Forum1404144231.835096.jpg
Gittins is offline Reply With Quote Quote
Old 30-06-2014   #17
Switzerland
No screw in my cars.
Official way (if it is more clear for you, for me not really... I pull and shake the cover, more at rear, until it comes) :
Punto 2012 Easy - 1.4 8V 77CV - Blue
Mkala is offline Reply With Quote Quote
Old 04-07-2014   #18
Quote Originally Posted by Mkala View Post
So it's not screwed on then and will just pull off? I want to make sure as I don't want to snap anything
Is there some sort of trick to this or do I just go ahead and pull at the cover from the back end first giving a shake from left to right?
Old 06-07-2014   #19
Switzerland
Just pull off
I took a pic for you :
Hope this helps, keep us informed
Old 07-07-2014   #20
Just pull off
I tried and tried to wiggle and pull that part off but only managed to slightly put up one side but as soon as I let it go it pulls back together again
Old 09-07-2014   #21
look on ePER
Did you find anything in ePER?
Old 12-07-2014   #22
Still ain't got a clue, don't even know if this sensor is the problem, still sat in the garage and can't even be arsed with it, worse car I have ever tried to find problems myself with and I don't think I'll ever get a fiat again, thanks for the help anyway :P......think I'll stick to VW's
Old 13-07-2014   #23
Switzerland
You're welcome.
But be serious 3 minutes : you are not thinking your car is bad for a 100$ sensor ??? You don't think buy a VW when the problem on your car is... a fu** Bosch electronic sensor ? Seriously ?
For your problem, was you able to disconnect the yaw sensor to see if the error change ?
If you cant solve it yourself, go to a Fiat dealer that know his job, ask he the cost and if it's correct let him do the job, it probably will not cost an arm and a leg...
Old 13-07-2014   #24
Like I say, I don't even know if it is that specific sensor that is the problem so it's going to cost 100+ to change that possibly, then 70 to test for faults, the cars only 4 years old. Takes 3 weeks to figure out how to take a plastic handbrake cover off :P I don't understand why there isn't a Haynes manual for this car!?
Old 13-07-2014   #25
Switzerland
I understand your point of view.
Once the plastic cover removed, changing the sensor is easy : two bolts.
Buying a sensor on ebay for less than 100$ is easy, too. You can make the exchange, if don't work better, back on ebay for selling.
This is the simplest/cost effective way I think.
You're right, a manual will be a good thing, and I'll be the second buyer after you.
But with electronic / electric on cars nowadays it's really difficult to repair/diagnose something without testing, software and good knowledge.
Old 13-07-2014   #26
Yeah think I'll try that as soon as I manage to get the plastic cover off. Seen the sensors for 30 and that is why I don't want to go to fiat to get ripped off, it's a shame there is not a specialist in my area
Old 10-08-2014   #27
Still can't figure out how to remove the plastic cover, could anyone post a video of it being done?
Old 21-08-2014   #28
Hey, I think I have found the problem, fixing it is the question.
It seems that I have noticed after removing the plastic shroud one of the wires to the yaw sensor has snapped of so it seems like this is the problem after all
How would I go about fixing this?
Can the plastic end connector be dismantled to re-insert the wire?
Would I have to buy a new connector end and then cut the wires and then solder or crimp them to the new end?Click image for larger version
Name:	ImageUploadedByFIAT Forum1408631332.450979.jpg
ID:	142520Click image for larger version
Name:	ImageUploadedByFIAT Forum1408631350.358149.jpg
ID:	142521Click image for larger version
Name:	ImageUploadedByFIAT Forum1408631360.212513.jpg
Old 21-08-2014   #29
Switzerland
Hey, happy you was able to open the central plastic to gain access to this sensor !
For the connector yes it can be possible to open it, but it's always hard to find were lock are. And when you see them, you need small tools they can do the trick to unlock.
Do you have any markings on connectors ? To find documentation on Internet, and to see how it's assembled.
Rear look like Mate-N-Lock connectors. The pin should come off from back, the yellow seal should come with. Cable and seal should be crimped to the contact.
Old 21-08-2014   #30
More info in the post below
Error with car U1715 Gittins Tech Talk 1 17-06-2014 01:17
