Thread Tools
Old 18-02-2014   #1
Slight Whine
Hi All,
I noticed today a slight whine while driving. The sound is directly proportional to road speed not engine speed.
I can't figure out where its coming from.
My gut feeling is it is either wheel bearings or gearbox output. The car has done 45000 miles.
Anyone else had this?
Punto Evo Sporting 1.6 Mjet 120BHP. Ambient White.
Manuel88 is offline Reply With Quote Quote
Old 18-02-2014   #2
Switzerland
Re: Slight Whine
If it change when you turn left / right it can be a wheel (apply / remove pressure to bearing). Test on a long straight line at 60-70 kmh, and "zig zag" (long turn to have the longest possible pressure on a side, not a slalom) and hear if noise change.
It can be you tires too, check if noise change when at same speed you change of road surface (new / old road)
Punto 2012 Easy - 1.4 8V 77CV - Blue
Mkala is offline Reply With Quote Quote
Old 02-06-2014   #3
Re: Slight Whine
Just a quick update. It was the rear wheel bearing. Both of them really really bad. Replaced under warranty. I think the fronts are starting to go so will try to get those done before the warranty ends in September.
Old 02-06-2014   #4
Switzerland
Re: Slight Whine
Thanks for update. Happy they are fixed now
Thread Tools
(T) whine...... slugworth1987 Cinquecento / Seicento 7 04-10-2011 22:04
(G) Whine Fiatseicento2002 Cinquecento / Seicento 10 12-01-2011 16:56
(T) Whine Cooks Grande Punto 15 27-07-2010 19:28
(T) Air Con Compressor Whine/Pulley Whine punto60_s Stilo 22 09-06-2010 13:05
whine!!!! psychofox I.C.E 25 03-05-2008 17:01
