Hello everyone , my left dipped beam doesnt work , the bulb is ok because i checked it in the right headlight, while in full beams the left one works. Any advice please. Punto evo 2010.
Not yet , do you think there is a circuit shortage there? What can i do there ? Strange because it just happened when i turned them on and off right after that when i turned them on again the left on didn't light up.
I had this but the other way around. Full beams ok, but one of the dipped beam's wasn't working.
Turns out mine was the bulb, as both dipped and main beam come from one bulb. Mine also didn't show on the dash that i'd got a bulb out, although it came on yesterday as one of the DRL's has blown
The dash indicator is for all exteriors bulbs except main beam (high / low), because you should see it if you miss one (and they take lot of current, it cost more to monitor it).
