S summer2013 Member Joined Jul 12, 2013 Messages 44 Points 71 Jan 15, 2014 #1 My dashboard is the same as the photo i have attached. I use the compartment next to where a tomtom could be attached to put spare change in..... but the spring/clip has broken and the door doesn't open correctly. Is this easy to fix? Attachments punto.jpg 48.9 KB · Views: 43
E EvoStevo Established member Joined Mar 1, 2012 Messages 681 Points 153 Location Northwest Jan 15, 2014 #2 I have the same issue, I have to put my nail in then push down to open it. Generally these are replaced, I dont think there is a spare available for the internals.
Mkala Established member Parked in the garage Joined May 10, 2012 Messages 724 Points 204 Jan 16, 2014 #3 Not sure something is broken ?? Sometimes the lock does not retract enough, so even when pressed don't unlock. It is the case ?
OP OP S summer2013 Member Joined Jul 12, 2013 Messages 44 Points 71 Apr 16, 2014 #4 Yes i think it is broken..
Andy Monty Moderator Staff member Parked in the garage Written 10+ guides Joined Apr 30, 2006 Messages 16,904 Points 3,632 Location East Yorkshire Apr 16, 2014 #5 your not going to like this but its a whole unit replacement incl the 2 centre blower vents I think i have done my home work correctly 735506247 + 68R is the part you want (the 68R is the as fiat describe it "PDA" version
