im Axle Specialists
Thread Tools
Old 07-01-2014   #1
Spare wheel help please
Hello everyone
I appreciate there are a lot of spare wheel threads but I can't find one that matches my wheels.
I have a 60 plate Punto Evo with 195/55/r16 87h (4 studs) wheels. Can anyone tell me which full wheel or space saver wheel would fit OK on the car. I am hoping to buy a second hand one with a jack on eBay so any links would be really appreciated.
I can see stuff for 15 inch wheels but not 16s.
All help greatly appreciated. Thank you very much.
Takesagestofindaname is offline Reply With Quote Quote
Old 07-01-2014   #2
varesecrazy has donated!
Re: Spare wheel help please
look on tyre sites to compare rolling figures.., as it's the circumference that matters while on the vehicle - could throw ABS errors otherwise,
195 is the width and the 55 is a percentage of that,
so 195 divided by 55 = @ 105 that is the actual height of the sidewall of the tyre,
as an aside the GP's , evo and 2012 punto are all on Vauxhall bolt pattern, ( 100mm pcd)
so a 16" er from Vauxhall may be cheaper..,
Charlie
Thanks Takesagestofindaname thanked for this post
Old 10-01-2014   #3
Cool Re: Spare wheel help please
Quote Originally Posted by varesecrazy View Post
Charlie
I have been looking on eBay and I keep finding things like "Genuine Fiat Punto 1999-2010 Spare Wheel Space Saver 135 80 R14" - which is the correct year for me but with a 14" wheel - would that work correctly given that the tyre is a 135/80?
Thanks.
Old 11-01-2014   #4
Hi Again,
I read that twice,
a 1999 to 2005 Punto is a FIAT and has a 98mm PCD
a 2006 to 2013 punto / Grande Punto is a GM ( Vauxhall) product with a 100mm PCD
so essentially the 4 wheel bolts are at different spacings and it will not fit BOTH vehicles !!
a ( grande)punto from 2006 on will fit perfectly as a wheel rim, you'll just need a tyre then to try and get the rolling diameter correct,
so what tyre you put on your 16" rim is down to you,
personally I would buy a "part-worn" tyre.. @ 15...the size will depend on the rim diameter,
buy that 1st , 15" or 16" = I think you'll struggle to get a cheap tyre with a 14" that will be the correct circumference??
as I said before there are some good comparison charts out there ( usually to aid in speedo accuracy..!!) that's what you need for ABS ..!!,
Charlie
charlie
Old 11-01-2014   #5
Moderator
Andy Monty's Avatar
Andy Monty has donated!
the grande /evo / 2012 spare
is a 175/65R15 84T tyre (as per the active spec car with steel wheels)
eg
http://www.ebay.co.uk/itm/FIAT-GRAND...item43c42e4654
(need a tyre)
or a new wheel rim and tyre
http://www.shop4parts.co.uk/?name=st...2817&sku=41217
less the fiat forum members discount if you become a donated member to the forums
Massive gash
Just a little touch up
Thread Tools
(G) Spare Wheel drofyb Ducato 2 26-11-2013 11:51
(T) Spare wheel & spare wheel carrier for 2011 Ducato 15" gullrock Ducato 4 03-10-2011 20:15
(T) Spare wheel Greenman Multipla 0 13-02-2010 20:11
(G) does full size standard wheel fit in spare wheel bay? pondweed Panda 3 17-09-2008 17:04
(G) Spare Wheel charliedurrant Multipla 2 14-06-2006 21:49
