eddieyeo
I know not many people will do this but seen as I bought a leather punto evo wheel to replace my plastic/rubber one which I hated, I had to remove my wheel and airbag. This is something I found useful which was posted in 2004!!!
Before removing and refitting the Air Bag module the following preliminary operations must be carried out.
For the punto evo you will need a Torx Bit Socket T50 to actually remove the wheel once the airbag is out.
- Position the vehicle with the front wheels straight.
- Turn the ignition key to the OFF position and extract it.
- Disconnect the battery leads and insulate them.
- Wait for 10 minutes before continuing.
FOLLOW ALL THE RECOMMENDED SAFETY INSTRUCTIONS
See IMAGE 1
1. Insert tools (1a) fully home in holes (1b) on the steering wheel.
See IMAGE 2
1. Push tools (1a) on the metal wires (1b) until they are released from the steering wheel retainers (1c).
This can be quite frustrating but you are basically feeling for a strip of metal to push down on at an angle until you here it release - quiet click sound - I used a flat head screwdriver
2. Move the Air Bag module slightly.
3. Disconnect the electrical connections (3a), (3b) and (3c).
4. Keep the Air Bag module.
Place the Air Bag module in the special cupboard resting it on a free surface with the bag facing upwards.
BEFORE REFITTING THE AIRBAG BE SURE TO TAKE THE CAR FOR A LITTLE DRIVE SO THAT YOU CAN TEST THE WHEEL IS STRAIGHT... I DID NOT DO THIS AND HAD TO DO IT ALL AGAIN TO REMOVE WHEEL AND LEVEL THE WHEEL
Refitting ( Removing )
- Observe the following precaution.
Handle the Air Bag module very carefully. Make sure that the battery is disconnected.
- If a new module is being fitted, position the labels. Remove the detachable part of the adhesive label from the new module and place it in the special folder containing the vehicle details (model, registration date, chassis number) and the serial number of the old module. The file should be kept for future checks. A new adhesive plate comes together with the module and should be stuck on top of the existing one. Beforehand, however, it should be perforated at the month and 14 years after the year in which the module is being fitted (e.g. 2005 for 2019).
- Position the Air Bag module connecting the electrical connections.
- Push the airbag module into its seat and engage the metail wires with the two steering wheel retainers.
- Connect the battery.
- Use an Examiner to check that the system has not acquired errors during the operation.
This process took me about 40mins but it would take me less that 5mins now
See IMAGE 1
See IMAGE 2
