RVLR. It says they must switch on when the engine is on, must be on when sidelights are either on or off, and must switch off when the headlamps are on.
I don't see how that can be interpreted in any other way.
Can you think of an example of an operational state of the 'other' lamps, which would result in the DRLs being off ? I can't.
No, they have to be operational.
Operational doesn't nessecarily mean on, just be operational - ie can be turned on if required.With the way you say they must be on because the must function in a certain way is on you could say that the regs say fog lamps must not be used if visibility is better than 100 meters so MUST be used if visibility is less than 100 meters, and like wise this is not the case, although advisable.Like I say, don't get me wrong, I think it should become legal requirement for them to have to be operational, but unfortunatly atm its not the case, what you've quoted confirms it.24. They must be operational
