Old 12-05-2013   #1
Punto Evo GP ISF Problem
Help, I bought my punto 10 months ago and I have now had enough of it.
It is only just 2 years old but I am having regular faults with it that the garage have yet to rectify.
Sometimes when I start my car in the morning the engine really struggles. It stutters, has no power and can cut out completely. After driving for a few minutes and trying to really put my foot on the throttle It clears and is then ok ish.
The 'Injection System Fault' light comes on and the warning light comes on. I also sometimes get a 'check engine' message.
Because of the intermittent nature of the problem, the garage are struggling to fix the fault.
They have so far changed one of the coils and updated the software on the engine. Hasn't worked!!!
Really fed up.....
LouHem is offline Reply With Quote Quote
Old 12-05-2013   #2
T-Jet!
Sweex's Avatar
Sweex has donated!
Re: Punto Evo GP ISF Problem
What engine?
My Grande Punto T-Jet Daisy
Sweex is offline Reply With Quote Quote
Old 12-05-2013   #3
Moderator
Andy Monty's Avatar
Andy Monty has donated!
what fault code?
if its intermittent and you have a android phone:
http://www.ebay.co.uk/itm/Bluetooth-...item1e7954c1dc
and download androd torque pro lite i think its called...
get the code and give it to the garage...
if its the 1.2 or 1.4 8v i would hazzard a guess at the MAP sensor but pointless just replacing parts till you find the fault
Massive gash
Just a little touch up
Old 13-05-2013   #4
Hi, thanks for replying...
My engine is a 1.4 Multiair 16V GP, think there is supposed to be a turbo in there somewhere too.
There hasn't been a fault code displayed, just says 'Check Engine'.
Any advice would be fab, now got my car booked in at the garage for Friday but would be good to take some ideas in with me
Old 13-05-2013   #5
Moderator
Andy Monty's Avatar
Quote Originally Posted by LouHem View Post
when the "check engine" message comes on does this light come on?
Massive gash
Old 13-05-2013   #6
Yes. is that the Injection System Warning?
Old 13-05-2013   #7
T-Jet!
Sweex's Avatar
Sweex has donated!
No thats the engine management light. You need to get a fault reader for when it comes on!
On another note i had a similair problem earlier... I have a grande punto t jet and i was driving along and then the car suddenly bogged down and started juddering like a misfire. Then afew seconds later it stopped.
The engine management light flickered on and off but the problem wasnt there long enough for it to register a code.
I had a coil fail recently which caused a similair problem but obviously a permanant misfire.
Thanks LouHem thanked for this post
Old 13-05-2013   #8
T-Jet!
Sweex's Avatar
Sweex has donated!
The multiair is a turbo like the tjet. Could be a similair problem.
Old 13-05-2013   #9
Unhappy Re: Punto Evo GP ISF Problem
I've been trying to trawl through the other posts on the forum.
A few people mention similar problems and the possibility of oil in the spark plugs????
Any thoughts?
Wish i'd of stayed with my old diesel.........
Just thought, i've already had one coil changed, how many does it have??
Old 13-05-2013   #10
Moderator
Andy Monty's Avatar
Any thoughts?
4 in total from memory (im sure those new multi airs are 4 cylinder)
the code light will reset itself after i think its 3 "clean" runs....
Just the look on the garage mechanics face when you tell them the car is throwning a P1111 error for example is usually priceless
Massive gash
Old 13-05-2013   #11
Where do I get the error codes from??
So far thinking it might be...
Spark plugs - oil contamination
Fuel injectors
Or
Gasket
Old 13-05-2013   #12
Quote Originally Posted by Andy Monty View Post
Yup, multiairs are 4 pots, its the twinair's that are the 2 pots.
Also Andy, I think its actually 15 clean runs? I know vauxhall and fords are around that number anyway.
I can pretty much guarantee that you don't have the turbocharged variant of the multiair since you have the GP (Special edition) and not a sporting.
As for multiair faults, can't say that there has been that many posted on here about them. mine (touches wood) has been great albeit slightly juddery when in the height of winter and when the engine is cold. But as previous member has suggested, without a fault code, we can't help unfortuantely.
scoop987 is offline Reply With Quote Quote
Old 13-05-2013   #13
Moderator
Andy Monty's Avatar
The ecu using a device like i have listed above (that ebay link and a android based phone or windows laptop with Bluetooth connectivity (there must be some apple based apps available too)
Massive gash
Old 13-05-2013   #14
T-Jet!
Sweex's Avatar
Sweex has donated!
Quote Originally Posted by scoop987 View Post
Can definitely confirm its 3 - 4 clean runs, it was with my GP
Thanks scoop987, Andy Monty thanked for this post
Old 13-05-2013   #15
Moderator
Andy Monty's Avatar
where the diagnostic port lives...
https://www.fiatforum.com/grande-pun...rt-access.html
Massive gash
Fiat Punto Evo. Blue and Me- Static Problem Antynwa Blue and Me 2 12-11-2014 14:41
Punto Evo problem with gear change :( romchick29 Punto Evo 11 02-04-2013 18:03
(T) Punto Evo oil change a problem? panmecheng Punto Evo 7 17-12-2010 22:34
Blue & Me Fiat Punto Evo problem erikjanneman Blue and Me 1 01-12-2010 14:59
(T) Punto Evo Sporting - Steering Problem? ntparsons Punto Evo 26 13-07-2010 01:40
