Old 10-03-2013   #1
Stop start punto evo
My Fiat punto stops then comes straight back on. If i take it on long run it works fine but then back to starting on its own next day. Do i need to take this to fiat?
Also passanger window goes down in auto but not up i can live with this though.
Stop start really bugging me might just sell it and lose money on it, think made mistke getting it.
Any help please thank you
Co2 is offline Reply With Quote Quote
Old 10-03-2013   #2
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: Stop start punto evo
If stop start 'starts' again straight away then you need your battery charged using the correct 'pulse' battery charger, get your garage to do this as they should of done/checked this at PDI stage as it's clearly mentioned on the check list sheet, so leave it overnight. I think a software update might apply to your model, but it is doing it simply because the charge is low. All cars have a similar set up so selling it for another car will make little/no difference. The fact you pay lower car tax is due to having stop/start.
Your window is working fine, the reason it does this is to stop you chopping your passengers head off for a laugh
Old 10-03-2013   #3
Moderator
Andy Monty's Avatar
Andy Monty has donated!
How old is your car?
i have just had to replace the battery on my 2010 1.4 8v due to it been knackered......
What you will probably find is the Dealership will want to keep the car over night to "pulse charge" the battery in an attempt to recover it.. If it works great
But if after a few days / weeks it stops working correctly it will probably need a new battery due to loss of capacity..
Do you have access to a multi meter?
if so when you park up pop the bonnet and lock the car leave the bonnet open but dont unlock the car again
(this is important for this test as it keeps the car "asleep" when you unlock it some of the cars components wake up eg interior light, dashboard)
anyhow measure the battery voltage after 10 minutes it must read higher than 12.72v dc any lower and that funny sensor on the battery negative clamp will instruct the system to shut down......
see here also:
https://www.fiatforum.com/500/318869...ml#post3177630
if the battery cant maintain capacity after ten mins thats more than likely your issue
Massive gash
Just a little touch up
Old 10-03-2013   #4
Moderator
Andy Monty's Avatar
Oh and on the window subject that is normal so you dont cut someones head or arm off
Beaten by T started typing and got distracted by a box of caburys roses..............
Massive gash
Old 10-03-2013   #5
My car is 2010 1.4 gp.
Old 10-03-2013   #6
Is stop start no good for short journeys? Got pay to change warranty over joke!
Old 10-03-2013   #7
Starts up between 10-15 seconds when engine has just been cold after good run works fine.
Any help thanks
Old 10-03-2013   #8
Moderator
Andy Monty's Avatar
on short journeys the start stop will not even come into effect its a rather smart system (when it works)
it monitors battery charge
(the alternator is beefed up to shove max charge in hence the special battery)
But if the car is "cold" it wont come on...
likewise if the heated rear screen is on it wont cut in (there are load of things than influence its functionality see the hand book)
Massive gash
Old 11-03-2013   #9
Forum Moderator
T14086's Avatar
T14086 has donated!
Quote Originally Posted by Co2 View Post
Charge it yourself then, you can get a draper BCI charger for £25 that will do the job.
Your car is nearly 3 years old, a certain amount of maintenance is required on your (or your local garages) part...again, selling it on will achieve.
Old 11-03-2013   #10
I've done just over 500miles in my Punto Evo 1.4, and its never worked. Sometimes it'll say "stop start unavailable" but the majority or the time it won't say or do anything..
JackDeean is offline Reply With Quote Quote
Old 11-03-2013   #11
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
Quote Originally Posted by JackDeean View Post
You done as advised by Andy above then
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
1993 Classic Panda Selecta, 1989 Panda 750L,
2015 Kia Soul EV, 2009 Qubo Dynamic Dualogic WAV & 2005 Panda Climbing 4x4 (LPG)
Most Easterly Pandas is offline Reply With Quote Quote
Old 11-03-2013   #12
So is my car doing what it should do or? Sorry for sounding silly but its a nice car just think stop start and the window has ruined it
I do alot of short journeys seems unfair i got take on long runs to charge it.
Old 11-03-2013   #13
Trader Rating: 2
Have you actually read any of what people have taken the time above to post?Seems unfair it doesn't work on short journeys, please, I suspect you'd be the first to complain if it stopped and didn't restart due to a flat battery.If you do as has been advised above it should work on short journeys as long as the engine warms up.
Old 11-03-2013   #14
So take it fiat?
Old 11-03-2013   #15
Moderator
Andy Monty's Avatar
Yes
get them to check the battery they will probably want to keep the car to try and pulse charge it over night...
so either book it in and arrange a courtesy car Or check out the local bus times
Massive gash
(G) Punto Evo - Start Stop Issues Tom6425 Punto Evo 13 06-08-2013 11:27
(T) Start&Stop in stop-and-go traffic Mondaugen 500 63 17-10-2011 08:07
(T) Start stop - How long does yours stop for? Ransoman Punto Evo 9 17-08-2011 12:52
(T) replacement start key with start/stop button D1Gi Panda 2 30-05-2011 14:54
