Thread Tools
Old 11-03-2013   #16
Re: Stop start punto evo
Been told by fiat pointless having battery charge as im only gonna be doing short runs after. Whole system seems pointless after only having the car a month im selling it.
Didnt do any of this when test drove it.
GUTTED
Co2 is offline Reply With Quote Quote
Old 11-03-2013   #17
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
Quote Originally Posted by Co2 View Post
GUTTED
You're selling a car over a minor fault which doesn't affect its running or functionality to get you from A-B in any way? How silly.
Go back to Fiat and tell them to sort it.
What sort of short journeys do you do?
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
1993 Classic Panda Selecta, 1989 Panda 750L,
2015 Kia Soul EV, 2009 Panda Eleganza & 2005 Panda Climbing 4x4 (LPG)
Most Easterly Pandas is offline Reply With Quote Quote
Old 11-03-2013   #18
Moderator
Andy Monty's Avatar
Andy Monty has donated!
GUTTED
Find another dealer who knows their stuff the reason the start stop is cutting the engine back in almost straight away is the battery voltage is dropping rapidly..Which a healthy battery should be able to support....
the fact your doing short journeys shouldn't cause the issue as it wont actually work at all if the battery is low on charge or the car is cold...
But a pulse charge MIGHT recover it if not it will probably need a new battery OR a software update...
Not all dealers have sent a staff member on the dedicated start stop course as this obviously costs time and money
Massive gash
Just a little touch up
Old 11-03-2013   #19
Doing about 20miles in the week max. Mainly gets used for weekends.
Old 12-03-2013   #20
Andy how much did it cost you to change you battery. Did you still have warranty?
Old 12-03-2013   #21
Moderator
Andy Monty's Avatar
Apparently the battery isn't under the 3rd year dealer warrenty but they could supply one for £220
so i went hunting i have the 1.4 8v and dropped one of these in uprated slightly by about 10Ah over standard......
http://www.justcarbatteries.co.uk/in...m-battery.html
But before fitting you must ensure its fully charged IT MUST BE A ECM battery due to the charge characteristics of the system...
Left the car on Friday night for the best part of 2.5 hours with side lights hazzards and a bank of strobe lights turned on (dont ask) and the start stop still works fine...
Massive gash
Old 12-03-2013   #22
Quote Originally Posted by Andy Monty View Post
Wow thats alot needs this already for my car. y do i feel as if ive made a mistake.
Wish i had more old car still
Old 12-03-2013   #23
Moderator
Andy Monty's Avatar
Got a mate who can lend you a charger before you go spending on a new battery?
How long have you had the car? if its new i would take it back to the dealership and insist they sort it if its under any form of warrenty
Massive gash
Old 12-03-2013   #24
Had the car a month. Didnt buy from fiat got it from local deal. Are these batteries easy to fit?
Old 12-03-2013   #25
Moderator
Andy Monty's Avatar
Yes all you need is a 13mm spanner and a 10mm spanner......
take your new battery and charge it fully using a car battery charger (ideally a smart one)
leave it to stand for one hour (this allows surface charge to dissipate)
next disconnect the battery negative cable (the red press tap and pull up the black plug)
then remove the negative terminal sensor using a 10mm spanner
then remove the live.....
unbolt battery retainer clamp at bottom of battery tray using 13 mm spanner
Carefully lift out battery
Clean battery clamps with wire wool
clean new battery terminals
if putting larger battery in remove the plastic wedge from the battery tray
place new battery in tray the correct way round as per the old battery
Refit Live terminal.... tap down before tightening
Refit negative battery sensor again tap down (if you look the battery posts are tapered)
Press on black plug till it clicks
apply vasaline (petrolium jelly) or battery terminal grease to the posts thoroughly
and jobs a good one...
You will need to reset the clock the CD player should be fine providing its an original unit (its coded to the body computer so the car see's it as its own)
then drive as normal
It will learn its parameters over a few journeys then settle down....
this is for the last GP but gives you an idea obviously there was no battery sensor and like
https://www.fiatforum.com/grande-pun...placement.html
Massive gash
Old 12-03-2013   #26
Moderator
Andy Monty's Avatar
NB i would still be tempted to give it a proper charge off the car before spending the money
Massive gash
Old 12-03-2013   #27
Thanks for your help seems like you no your .
Cd will defo be ok when take battery out.
Old 12-03-2013   #28
Would fiat do that? Could it not loose charge again though? As said before dont use car alot in the week.
Old 12-03-2013   #29
Moderator
Andy Monty's Avatar
Yes but will probably charge you for the privilege (no pun intended) for under an hours labour rate you could get your own decent charger
An alternator due to its nature can't restore charge to a deeply discharged battery.... Its rather techical but the battery has 2 types of charge Surface and deep charge the alternator only charges the surface (which is what is used when cranking)
err go get a cuppa and your reading glasses........ and look at this link
http://www.smartgauge.co.uk/surf_chg.html
So a prelonged charge at the correct rate can shove a decent charge back into a battery and up its capacity / deep charge
(with that you can connect the fly lead to the battery and keep it topped up whilst its stood without lifting the bonnet)
http://www.autoexpress.co.uk/accesso...y-charger-test
Massive gash
Old 13-03-2013   #30
Us there anyway of turning this off all together?
Thread Tools
(G) Punto Evo - Start Stop Issues Tom6425 Punto Evo 13 06-08-2013 11:27
(T) Start&Stop in stop-and-go traffic Mondaugen 500 63 17-10-2011 08:07
(T) Start stop - How long does yours stop for? Ransoman Punto Evo 9 17-08-2011 12:52
(T) replacement start key with start/stop button D1Gi Panda 2 30-05-2011 14:54
