Old 01-02-2013   #1
Dipped Headlights Not Working BUT ALL OTHERS WORK!
So my full beam works, DRL are working, side lights and fog lights are working but the normal dipped headlights just aren't working.
Working yesterday, got in the car today, turned them on and nothing. Not working. And it's BOTH?!
Both lights stopped working?
Any ideas?
(Punto EVO GP 2010)
lejc2425 is offline Reply With Quote Quote
Old 02-02-2013   #2
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Re: Dipped Headlights Not Working BUT ALL OTHERS WORK!
Quote Originally Posted by lejc2425 View Post
Any ideas?
(Punto EVO GP 2010)
You checked both bulbs? (its not impossible for them both to blow at the same time)
If not it's probably the stalk thats faulty.... this is really a garage job as the air bag / steering wheel needs removing to replace the stalk unit
Massive gash
Just a little touch up
Old 02-02-2013   #3
If it was the stalk, would I still be able to turn on full beam, side lights etc with it?
I'm hoping it is as simple as both bulbs...
Old 02-02-2013   #4
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
Check the bulbs first, easiest job, and go from there
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
1993 Classic Panda Selecta, 1989 Panda 750L,
2015 Kia Soul EV, 2009 Panda Eleganza & 2005 Panda Climbing 4x4 (LPG)
Most Easterly Pandas is offline Reply With Quote Quote
Old 02-02-2013   #5
Moderator
Andy Monty's Avatar
Yes each mode of the stalk has its own switch contacts : thumb:
Massive gash
Old 03-02-2014   #6
Hi i have the same problem. Both my main beam lights wont work (full beam and side lights) are fine. Fuses are fine and bulbs too just wont work at all :/ please help.
Lankyluke1990 is offline Reply With Quote Quote
Old 03-02-2014   #7
Switzerland
Do you have MutltiECUScan to diagnose ? I think you can test lights, it can help to find if it is a command or an actuator fault.
Did you do some measurement with multimeter ?
Punto 2012 Easy - 1.4 8V 77CV - Blue
Mkala is offline Reply With Quote Quote
Old 03-02-2014   #8
Trader Rating: 2
Quote Originally Posted by Lankyluke1990 View Post
You've mentioned main beam twice...is it dipped beam which isn't working
Quote Originally Posted by Mkala View Post
Old 03-02-2014   #9
Yeah sorry dipped beam lol. Both bulbs are fine and fuses are fine just wont work at all :/
Old 03-02-2014   #10
You can rule out the stalk by using the follow me home lights as this uses the "Main beam" flasher to operate.
Park up, Engine off and then pull the light stalk towards you. You will see a message "Follow me 30s" on the screen. The headlights should be on.
My money would be on Bulbs. Change them before spending any money on anything else.
Driving: Alfa GT 3.2 V6 in black and Abarth 595 145bhp in Red.
Ransoman is offline Reply With Quote Quote
Old 03-02-2014   #11
Trader Rating: 2
How have you tested the bulbs
Old 04-02-2014   #12
Albania
I had the same problem two weeks ago , i sent it to fiat and it was a cable fault, they changed it for 30 mins without any complicated work, afterthat it was a ok, they used a multimeter to check it.
swiss16 is offline Reply With Quote Quote
Old 04-02-2014   #13
Trader Rating: 2
Quote Originally Posted by swiss16 View Post
Can you find out what cable was at fault please.
(T) Dipped Headlights packed up no1sourlung Punto (Mk2/2b) 3 07-08-2017 12:58
(T) Ducato dipped headlights don't work rayryan99 Ducato 1 07-06-2016 11:18
(T) changing dipped headlights vodkacab Punto (Mk2/2b) 11 18-08-2013 13:57
(G) AAARGH!!! Headlights wont work on dipped beam and the cooling fan doesn't cut in!!! benjiman46 Cinquecento / Seicento 9 29-01-2009 18:04
(T) Marea Dipped Headlights Gordon Bravo / Brava 2 31-12-2003 01:16
