Off Topic The importance of a vehicle check / Inspection
East Yorkshire
If planning on buying a new (second hand car) Before parting with your hard earned brass GET IT CHECKED OUT....
come across one on the dreaded bay of e ok they say its had a new bonnet and bumper in the advert but knowing the car a little lets you into a whole new world of what to look for......
but lets play a little fun game of spot the faults (click to enlarge) :)
there are 3/4 that jump out at me straight away :bang:
First one is headlight misaligned
Washer bottle sitting down (Never looked at mine from that angle)
Missing plastic at the O/S, can see grass.
O/S metal mangled?
Not sure about that earth cable, doesn't look right.
Suppose i ought to list what i have seen
Front cross member plate looks bent
RHS Chassis leg is bent downwards
Someone has been at the ECU plugs look at the tape on the closest one
Start stop earth lead been cobbled onto a mk1 GP quick release
The starter (i think) Relay from front slam panel isnt there its under dodgy earth post
Ns headlamp bracket snapped
Off side inner wing is mangled
something looks wrong with brake fluid bottle lower spigots
ecu earth tag missing
air box intake bracket looks to be missing
That Earth lead would send me running to start with
Along with the damaged light tang - it starts saying somebody has crashed it
The battery means they've had troubles and or remove it regulary for some bizarre reason and put a odd easy release on it yes....
I'd be very quick to slam the price or walk away
Ziggy
Ziggy
judging by the "new" earth strap i bet the old / original battery was damaged........
Sadly there are a lot of people who know nothing about cars How often on here do you see people asking basic weekly check type questions? this is no slur on them for asking but more a heads up to take someone with you before you hand over your monies :)
People get new car blinkers on i looked at a evo before this one but the test drive there was something amiss having driven a "straight" GP for about 5 years it drove worse than mine..... Took a mate with me after garage hours first thing he saw was the evidence of a respray which i had failed to spot yet it jumped out at you once you had seen it.... fresh set of eyes and all that ;)
Anyone got a pic of the quick release earth cable out of a car? Is it just the quick release the cable and a spade on the end? id like one for my Bravo.
Before i accidently read andys results i got;
Broken passenger headlight fixing
No drivers wing or damaged
A loose hydraulic or aircon pipe in the bottom of the engine bay (far side of pic)
I think the drivers side chasis leg and inner wing are bent?
Strange earth business
which one the original gp?
https://www.fiatforum.com/attachment.php?attachmentid=84885&d=1292875596
or the Start stop version with the red tab (which is used due to the start stop module
