headlights or day time running lamps? Is the green lights on dash warning light on? Tail lamps? Do they go off with the ignition? do you have front fog lamps?
Know you said headlights but just wanting to clarify so you get the right advice
similar to this but i think the evo unit is different due to the overtaking indicator function
Lane changer? If so its a software feature, not stalks
Think its a 2 stage switch as if you flick it you get the 3-5 flashes but latch it and it will only give one even if you cancel it immediately
Interesting, on Bravo if you latch and release instantly you still get lane changer kick in. Although they're same stalks as Stilo I believe so probably not been modified as no reason to.
