When you use the electric window on the drivers side a little push will make it go down all the way, a little pull makes it come all the way up.
Should the passenger side act the same way?
from the drivers side I can push once and the passenger window goes down all the way but a single pull only brings the window up for as long as you pull the switch.
Could there be a problem with the mechanism on the passenger side?
I expect this is covered under warranty so want to get it in soonest before it runs out.
