General Steel Spare Whell and Jack Kit
89james
HI
I really hope someone can help me with this im trying to locate a
15 inch Full Size steel wheel ( to fit the hole in my boot) with tyre or with out
1x Jack full set
its to fit a Punto GP
im not really fussed on new or second hand at all
Thank you
thank you for the welcome, ive read some of your posts and you seem to be the man of wisdom... thank you for your reply at least i know the grande punto wheels and jack set match....
just another qucik question with my puntrue repair kit what damage does the shall we say builders expand foam do to my tyre and the after affects when being repaired
Thank you
oh p.s and ive noticed that where my front bumper meets my front wheel archs it sits a little proude where the two creases meet, is that the normal look ? thank you once again
I can confirm the GP set and wheel fit (i pillaged mine out of my last car prior to part -ex and had to fit it about 3 month ago at night in the dark and rain on a A-Road :mad:
Im not sure of the exact ingredients of the Fiat Fix and Go kit older fast fix stuff used to contain an array of chemicals and something that ate into the rubber rendering the tyre useless and set leaving the tyre un-balanced
Newer substances are more eco friendly and contain a mixture of liquid latex and corn flour among other things
Problem is hardly any garage / fast fit place wants their staff or equipment covering in the stuff so will more than likely say the tyre is screwed to save on having to clean it all out of the tyre and off the floor
As for the bumper and front wings... my back bumper is the same however i managed to slacken the screws off and wiggle it a bit closer then re tighten
this is my front bumper its a bit proud by the headlamp (never noticed before so im blaming you :p )
Yeah it a common thing garages chucking tyre after haveing tyreweld etc used on them.....
Oh rite im just and eagle eyed fiat owner, i hope this has'nt lead to you looking for something or tighten up or changing clips to the bumper / wheel arch lololol......
just another quick question ive got some exposed wires etc uder the bonnet towards the head lamps and bark fluid well, there not wrapped up with insurlation to where they connect.... checked my dads Alfa and there all sealed but my older bros 500 has the odd one, is this the same with your fiat ???
Thank you
Hi andy in repley to the front bumper, is it held on by push studs or screws and mine is a little prouder on the right side that the left and, im have comments from my mates that the front bumper has popped, but this is how i collect it from the dealer.
and help or adivce on how to tighten up or where the studs or screws are located. thank you...
with ur picture you posted its the two creases where the front wind and bumper meet as the line heads towards the head light
