Now I have found thetemperature sensor and made some tests.
(It is a cold day today,-10 °C outside. The following test is done with the motor running.)
I first warmed the sensorup with a hairdryer to +10 °C.
Then I carefully sprayedcooling spray on the sensor and looked on the display to see the temperature drop.When it came down to 0.5 °C it also showed 0.0 °C for a few seconds before itshowed 0.5 °C again. When I then sprayed some more cooling spray on the sensor,nothing happened, until it showed -1.0 °C. I could then continue cooling itdown in 0.5 °C steps to -12 °C.
Then I used the hairdryeragain to warm the sensor up. But nothing happened on the display!!! Why?? Icould feel on the sensor that it was nicely warm.
I turned off the engine andstarted it up again. Still -12 °C from the warm sensor. I repeated this severaltimes without any success.
With the motor off Iunplugged the cable to the right door, and placed it back again. When I thenstarted the engine again, it showed +24 °C!!!
How come that it showcorrect temperature when it drops down, but not when it goes up?
I have made some films fromthis experiment that I will show to the guys where I bought the car. Today Ihave had this car exactly one year. And there are some things that are not workingas it shall…
Best regards,
/Sören
