Old 30-03-2011   #1
Headlight heat damage..
I've noticed one of my headlights has obviously gained heat damage & will need to be replaced. (Sorry, not giving too much info atm til I know where I stand)
I was wondering if they'll point out there's none-standard (but right spec) bulbs fitted would Fiat argue out of the warranty?
2010 Punto Evo Eleganza - 1.4 Multiair (105) - Progressive Black
Blank2k2 is offline Reply With Quote Quote
Old 30-03-2011   #2
"Spirito Di Punto"
TJ07's Avatar
TJ07 has donated!
Re: Headlight heat damage..
Quote Originally Posted by Blank2k2 View Post
I donít doubt that they will try it on for that very reason, however in the manual it only states fitment & wattage therefore as long as the bulbs used are the same fitment & wattage they donít really have a leg to stand on. So I would not accept any nonsense.
Punto Evo Sporting 135 MultiAir Ambient White,
Red Wing Mirrors, Smoked Wind Deflectors, Team Dynamics Jet 17" alloys, Abarth Evo Exhaust & Suspension, Side Rubbing strips, Red Brake Calipers, Rear Mudflaps, Clear Rear Fog Unit, BMC Panel Filter, TMC Box, Osram Nightbreakers, Mtec Superwhite side lights, Mtec Superwhite DRL's, Chromed Indicator Bulbs, Smoked repeaters, Alloy Pedals, Armrest.
TJ07 is offline Reply With Quote Quote
Old 30-03-2011   #3
Booked it in for friday, I'll take the bulbs out & double check there right before taking it in just to be on the safe side (but i'm sure they are as everyone who changes there drl are using them)
Old 30-03-2011   #4
Anything non standard not covered by warranty, why should it be ? With you not giving much away cant comment any further.
Mal126 is offline Reply With Quote Quote
Old 30-03-2011   #5
F*** Its A Turbo
JackFi's Avatar
Trader Rating: 1
JackFi has donated!
Baghdad Bowling Champion
Finland
Quote Originally Posted by Mal126 View Post
So if a bulb goes you've got to get a replacement directly from fiat then? I think not.
JOIN US! Just search "BRAVO ENTHUSIASTS" ON FACEBOOK!
JackFi is offline Reply With Quote Quote
Old 30-03-2011   #6
"Spirito Di Punto"
TJ07's Avatar
TJ07 has donated!
The bulbs used are the same as the standard bulbs as specified in the owners manual. If a specific brand was to be used then it would have to be stated in the manual, however the replaced bulbs do conform to that stated in the manual. For example if you were to replace a tyre there is no specified brand only the size and load/speed rating etc. The same applies to the bulbs!
Old 30-03-2011   #7
I'm not giving too much away right now encase Fiat do check these forums.. (Which apparently they do)
But the aftermarket bulb package says "MTEC - T20 7440 - 12V-21W" - Which matches the stock bulb i've taken out.
I'm just hoping Fiat don't turn around & blame mtec and tell me to chase them up instead.
Old 31-03-2011   #8
F*** Its A Turbo
JackFi's Avatar
Trader Rating: 1
JackFi has donated!
Finland
Tell them to jog on if they do, you used the correct spec bulb so they must sort it out.
Old 01-04-2011   #9
Quote Originally Posted by Punto.Jack View Post
Yep that's what im thinking...
But im warey, with Phillips / Bosch etc I have a leading consumer brand that Fiat wont want to argue over...but mtec, some random japanese brand... if there spec's are off, I have no come back.
We shall find out tomorrow...
Old 01-04-2011   #10
I had the same thing happen 2 me I put the original bulbs back in and took it back 2 the garage
djbish is offline Reply With Quote Quote
Old 01-04-2011   #11
It was fixed under warranty, but I put the original bulbs in before hand.
And I enquired about what if such a problem theoretically happened with after-market bulbs, basically if its a main brand bulb it'll be no problem but if its something more obscure (mtec...) then it'd have to be "investigated"
I don't think ill use the mtec bulbs again, so that means im on the lookout for some white look main-brand DRL bulbs.
Old 01-04-2011   #12
F*** Its A Turbo
JackFi's Avatar
Trader Rating: 1
JackFi has donated!
Finland
Cool well atleast you got it replaced though, I wonder if the m-tecs were the cause of the problem.
Old 01-04-2011   #13
Yeah im wondering that too, I might take a closer look at the other lamp to see if theres any sign of damage.
I know someone asked about mtec bulbs / heat once before but don't know if anything came of it
Old 01-04-2011   #14
"Spirito Di Punto"
TJ07's Avatar
TJ07 has donated!
Just checked mine and they are fine!
I think your right about someone mentioning a problem with scorch marks after fitting mtec bulbs, although Iím pretty sure is was headlight bulbs rather than DRLís.
Iíve had a quick search through google on mtec bulbs and cant find any real issue with them, most people seem to be fairly happy with them (mainly Honda owners though).
Old 02-04-2011   #15
F*** Its A Turbo
JackFi's Avatar
Trader Rating: 1
JackFi has donated!
Finland
You know what needs to be done?! Someone needs to test the originals & then the mtecs & see if there running hotter that the standards using a food phobe or something.
(G) Headlight clamping kit (instead of new headlight)? Berlic Grande Punto 2 19-02-2011 19:11
(G) No heat/some heat/misty windows electron Punto (Mk2/2b) 8 20-02-2010 15:36
(T) punto mk 1.2 8v heat manifold heat shield needed or not? mcjacko1987 Punto (Mk2/2b) 5 11-05-2009 20:45
automatic headlight adjustment and headlight relay lost_aussie Lets Talk FIAT 2 11-06-2007 22:42
