Just PM me for anything you wish to order mate, or drop a post in the requests section of my traders section.
By through the forum (cheaper than ebay)
Just give me a shout pal, was it you who bought the exhaust trim off me on ebay?
Yeah it was, clamps on fine and looks cool, also just left you feedback as I complety forgot too
Sneaky price change thou
Ok difficult to explain but here goes!Alrighty! After 2 months or so of floating around my boot, I've decided to fit it!
Any tips on how to tighten up the screw on top of the lamp?
I managed to undo it through bending twisting and all things bad & abit of luck, but I haven't been able to tighten the screw again.... so right now the light wiggles alittle bit if pressed.
I think i'll be going out on the pull soon to find a girl with skinny wrists to get her under the car for a screw .....But if there's a trick to it let me know!
Tighten the top screw first, you have to twist the lamp unit back into the bumper so that you can fit your hand through the actual light unit hole in the bumper and tighten the top screw with a small screwdriver. Once the top screw is tight enough, then go under the bumper and push the light unit back into the correct position and fit the bottom screw.
Hope that makes sense!
