Thread Tools
Old 12-02-2011   #1
IronHorse has donated!
Check Engine Warning
Im going to take the car in to get this investigated but have found a way to develop a warning light on my Evo Sporting, Ive recently bought a new house with a VERY steep drive to the house if holding the car at the bite point the car then gives a "Check Engine" then "Stop Start Unavailable" this can then be cleared by pressing the Stop Start button that disconnects the system start the engine and its gone?!
Anyone had anything similiar?
One thing ive noticed is that the hillstart system works especially well Holds very well switching between 1st and reverse
Multi-Air Turbo
IronHorse is offline Reply With Quote Quote
Old 12-02-2011   #2
Quote Originally Posted by IronHorse View Post
I've had it happen once and my dealer sales manager told me to call him strauight away if it happened again.
Although I now get when its stopped I put my foot on the clutch to start it again it starts then beeps anmd flashes up ' press clutch' when my foot is already on the clutch???
xSianx is offline Reply With Quote Quote
Old 13-02-2011   #3
Re: Check Engine Warning
Sounds similar to the "fault" reported on the 500;
https://www.fiatforum.com/500/205211...op-owners.html
Essentially when riding the clutch the start stop controller flags a clutch sensor fault when the clutch is held mid way for more than "x" seconds (think it was 3 at first but software patched to 10 secs IIRC)
Drove BNW 1.2 Sport, with boot light, ESP and 15" multispokes.
Ordered 15th June 2009, collected 25th September 2009. 10000 miles completed 6th August 2010.
Traded in for Suzuki Swift Sport 10th May 2014.
zanes is offline Reply With Quote Quote
Old 15-02-2011   #4
It does indeed.... Interesting!
Multi-Air Turbo
Old 18-02-2011   #5
"Spirito Di Punto"
TJ07's Avatar
TJ07 has donated!
Well believe it or not this issue just appeared on my Evo today, I have had this problem before not long after getting the car and it was supposedly fixed…. apparently it had been something to do with a sensor on the gearbox.
On phoning the dealer today to get it booked in and looked at I reminded them that the car had suffered from the same symptoms before, however they told me that these warnings will show up simply if there is a problem, it doesn’t necessarily mean it is the same issue.
Low and behold the problem disappeared just after I booked the car in but it should certainly be logged on the ECU so will hopefully see what the cause is on Monday.
Punto Evo Sporting 135 MultiAir Ambient White,
Red Wing Mirrors, Smoked Wind Deflectors, Team Dynamics Jet 17" alloys, Abarth Evo Exhaust & Suspension, Side Rubbing strips, Red Brake Calipers, Rear Mudflaps, Clear Rear Fog Unit, BMC Panel Filter, TMC Box, Osram Nightbreakers, Mtec Superwhite side lights, Mtec Superwhite DRL's, Chromed Indicator Bulbs, Smoked repeaters, Alloy Pedals, Armrest.
TJ07 is offline Reply With Quote Quote
Old 21-02-2011   #6
"Spirito Di Punto"
TJ07's Avatar
TJ07 has donated!
Just got back from the Fiat garage and it was apparently the same issue as it had been the last time, the “neutral sensor” needing recalibrated.
When I reminded the garage that I had had this issue before, they checked and did confirm it was the same problem, unfortunately the Fiat website was “Down” so I am going to have to wait for them to be able to check if the part needs replaced, but they reckon it will.
In the mean time the error has been cleared and the cars working fine.
Old 21-02-2011   #7
Go fast young man
shadgrind's Avatar
shadgrind has donated!
Same problem as I have had twice, first time I got it reset by a dealer. This time it went away all on its own, I have already booked it in to get it looked at though. Will see what they say.
Fiat 500 1.4 16v Lounge Start/Stop
Passadoble Red.
shadgrind is offline Reply With Quote Quote
Old 22-02-2011   #8
"Spirito Di Punto"
TJ07's Avatar
TJ07 has donated!
Got a phone call back from the garage this afternoon saying that Fiat have given the go ahead for the sensor to be replaced.
Thread Tools
(T) "Check engine" warning light airlog Panda 4 04-12-2010 22:44
(T) Injection System Warning Light and "Engine Check" Message scotlandstopboy Punto (Mk2/2b) 8 10-01-2010 00:51
(G) New 1.6 Mjet: CHECK ENGINE warning Aresby Grande Punto 12 22-11-2009 16:31
(T) Check Engine Warning Deano.UK 500 2 26-10-2008 17:25
