Technical 1.4 GP punto evo
grandepuntomad
Hi
I have a punto evo gp and it has a ratle coming from the front passagner side when doing 40-60mph
Hi
Is this such a quiet rattle you couldn't really show it to a dealer & no1 else can hear it?
or is it a loud obvious rattle?
mines got a quiet one when doing 40-60mph, no1 else can hear it but me and its been like it since i picked it up... never been able to figure out what it is!!
Same!
I think it gives the car abit of character..... Chirping away :D haha
Been to my local Fiat garage 5 times and mechanic heard the noice a says it wind noice and there nothing they can do about it :bang:
Very Unhappy have to turn radio up
I get a vibrating noise from my drivers side between 40 - 60, but only if its's been raining - its the noise of water draining off the edges of the wing mirrors!
It's almost like a chirruping noise.
I also get an occasional rattle from the passenger side, it's the metal of the passenger seat belt fasterner rattling against the door frame....!
It's either the seatbelt rattling, or the bearings underneath the seat are loose I imagine. Mine is the actual seat rattling and its usually solved by pulling the passenger seat forward (rather than having it all the way back like it usually is)
I should get it looked at but it doesn't cause me a huge amount of bother really.
Mine stops when i lift the seat ie from its lowest posistion and slightly bring in from the longest posistion.Bloody annoying though
Hi
Hi
Could it be the wheel arches lining? I had a similar problem on my Alfa Mito and found out that the linings were flapping a bit with the wind producing a similar noise to what you describe.
HTH
Hi
HTH
Did it sort it out & wat did you use to stick it down
