im Axle Specialists
Old 22-01-2011   #61
"Spirito Di Punto"
TJ07's Avatar
TJ07 has donated!
Re: Trend setter
Quote Originally Posted by baby278278 View Post
They look really smart Actually your whole car looks really smart n all
Thanks!
Punto Evo Sporting 135 MultiAir Ambient White,
Red Wing Mirrors, Smoked Wind Deflectors, Team Dynamics Jet 17" alloys, Abarth Evo Exhaust & Suspension, Side Rubbing strips, Red Brake Calipers, Rear Mudflaps, Clear Rear Fog Unit, BMC Panel Filter, TMC Box, Osram Nightbreakers, Mtec Superwhite side lights, Mtec Superwhite DRL's, Chromed Indicator Bulbs, Smoked repeaters, Alloy Pedals, Armrest.
TJ07 is offline Reply With Quote Quote
Old 22-01-2011   #62
"Spirito Di Punto"
TJ07's Avatar
TJ07 has donated!
Re: Trend setter
Quote Originally Posted by MrBoney View Post
The reason I told you they do fit is because there is a grande sporting owner who's dealer actually fitted them for him with sideskirts and he has photos with them fitted
Ok had a look at the Grande section and found a fair bit on the fitment of front mudflaps to models with side skirts, seems strange as some people have had no problem in fitting them but others have .
It would seem to depend on how much of a gap you have between the side skirt and the arch, unfortunatly I have a fairly big one, the other way to get round the problem would appear to be the following which I have copied from another users post: (Thanks to Pigflute)
(Front Mud Flaps:-
According to the Fiat website, front mud flaps are not compatible with cars equipped with sideskirts. This is true, however, if you are prepared to undertake a minor modification to the mud flaps then they can indeed be fitted.
For anyone who is interested the process is as follows and was done without the need to remove the wheels (simply rotate the steering lock as required to improve access):-
  1. Hold the mud flap in position on the car and using a pencil, trace around the profile of the sideskirt - you need be careful here, as get the position wrong and you will trace the profile in the wrong place on the mud flap.
  2. Using a Stanley knife, cut out the profile that you have traced onto the mud flap. Be sure not to cut off any material from the vertical or horizontal tabs and remove less material than you think necessary and then offer the mud flap up to the car - this allows you to ensure that you only remove the material necessary and ensure that you achieve a good fit. Repeat this process, trimming the mud flap until you are happy with the fit. I have attached a picture showing the mud flaps that I modified, prior to fitting them to the car. With the horizontal and vertical tabs left untrimmed, these can then be slipped between the black plastic wheel arch liner and the side skirt (provides additional support to the mud flap - the horizontal tab fits on the front side of the wheel arch liner and not the reverse side as shown in the Fiat mounting instructions).
  3. Offer the mud flaps to the car and using a braddle (or other sharp pointy thing), mark the position of the inner most hole of the horizontal tab on the mud flap on the black plastic wheel arch liner - you can then 'drill' the required mounting hole. I only used the inner most mounting hole as the outer most hole is covered by the side skirt. I used a small 'watchmakers' screwdriver to make the first small hole (just held it against the wheel arch liner and rotated it until went through and made a small hole). I then used a couple of drills which I held by hand and used these to increase the hole size to that required by the 'self-tapping' attaching screw.
  4. Attach the 'screw clip' to the outer hole of the horizontal tab on the mud flap and offer the mud flap to the car - ensuring that the horizontal tab is located on the front side of the black plastic wheel arch liner. Using a screw driver (there is enough room) screw the self tapping screw from the rear side of the black plastic wheel arch liner and into the screw clip on the mud flap (don't forget the washer under the screw head). This basically attaches the horizontal tab in the reverse method to that shown on the Fiat instructions but means that you can slide the untrimmed horizontal tab between the wheel arch liner and the sideskirt (giving additional support in place of the omitted second horzontal screw - as this hole is covered by the sideskirt).
  5. Secure the vertical tab to the wheel arch using the two clips provided as shown on the Fiat instructions - this is really simple and hopefully very obvious.
  6. Repeat for the other mud flap.
I have also attached a couple of pics showing the finished mud flap installation.
In all the front mud flap installation took approx 3 hrs. Most of this was figuring out what I was going to do and then carefully trimming the excess material from the mud flaps - it's worth taking your time here, as get it wrong and you've just wasted your money.
Good luck to anyone who fancies trying this. It shouldn't really be necessary if only Fiat could be bothered to design and sell mud flaps for cars with sideskirts.)
Name:  Mud Flap 01.jpg
Name:	Mud Flap 02.jpg
Old 22-01-2011   #63
Ginger
MrBoney's Avatar
MrBoney has donated!
Re: Trend setter
Quote Originally Posted by TJ07 View Post
(Front Mud Flaps:-
Attachment 85865
Attachment 85866
Seriously impressed mate
Punto Evo, 1.4 MultiAir 105 Eleganza 5dr, ESP + Hill Holder, Ambient White, Leather Interior (front armrest and ambient lighting), Skydome Roof, Style Pack (cornering fogs, rear electric windows and side rubbing strips), Metallic Bumper Mouldings, Reverse Parking Sensors, Mudflaps.
MrBoney is offline Reply With Quote Quote
Old 28-01-2011   #64
"Spirito Di Punto"
TJ07's Avatar
TJ07 has donated!
Re: Trend setter
One thing that always bothered me with the Evo’s interior was that the section where the knobs for the fan, heater, etc. doesn’t in my opinion blend in with the rest of the dash (unless you’ve got the full climate control kit that is), so after alot of hunting I got some chrome surrounds for the knobs to help pull it all together (they were a nightmare to fit though):
Old 28-01-2011   #65
Fordyl has donated!
Re: Trend setter
I'm am not to sure about this one
Still a cool idea !
Fordyl is offline Reply With Quote Quote
Old 30-01-2011   #66
mjt has donated!
Re: Trend setter
I actually prefer the dials on the air con unit more than the one with the climate control. I always disliked the look of the climate control buttons/display ever since I had my Grande Punto and this continued into my Evo Eleganza. One thing I don't miss I have to say.
Punto Evo GP 1.4 16v Multiair
Progressive Black + Style Pack + Visibility Pack + Parking Sensors + Cruise Control + Rain Sensor
Blue&Me Tomtom
Nokia N8-00
mjt is offline Reply With Quote Quote
Old 30-01-2011   #67
Ginger
MrBoney's Avatar
Re: Trend setter
Quote Originally Posted by mjt View Post
What are you mad?!!!!
The climate control looks amazing, and the extra screen is cool! lol
Old 30-01-2011   #68
mjt has donated!
Re: Trend setter
If you say so...
Mad? Possibly.
Blue&Me Tomtom
Nokia N8-00
Old 30-01-2011   #69
Ginger
MrBoney's Avatar
Re: Trend setter
If you say so...
Mad? Possibly.
Buying Fiats makes us all mad lol
Old 31-01-2011   #70
Fordyl has donated!
Re: Trend setter
I would love the climate control controls.
Think it looks awesome. And you must be insane to not like it !
Old 01-02-2011   #71
Trader Rating: 1
Re: Trend setter
To be honest even in heavy fog, which we get all the time living by a river and by the sea, I only use my front foglights.
Really, I think ive used my Fog lights once in the last 3 years,
paul100hp is offline Reply With Quote Quote
Old 01-02-2011   #72
Ginger
MrBoney's Avatar
Re: Trend setter
Quote Originally Posted by paul100hp View Post
I was on about not using my rear foglights even in heavy fog. Only the front ones. As I said I live by a river by the sea so fog is quite often. Once a week minimum during the winter
(S) Trend starter? Quiz Bravo 10 07-09-2009 20:26
(G) Bucking the trend. There is a god. bozzy Stilo 17 12-08-2007 09:03
Disturbing US trend Virmin Leisure Lounge 14 21-02-2007 18:54
(G) Bucking the trend philmgro Stilo 14 16-01-2006 22:35
