Old 09-11-2010   #1
Unhappy 1.4 8V tappet noise from cold
Hi, does anyone else's 1.4 8V Evo have a tapping noise from the engine when driving off from cold ? Mines done just 1,050 careful miles, the tap is not noticeable at tickover but comes on when accelerating and increases with engine speed disappearing after about 2-3 miles. I am wondering whether this will go away as the miles build or should I take it to my dealer (I am guessing they will probably just say not to worry!) Apart from this I am really pleased with this little car, far more refined and modern than the 1.6 Focus it replaced.
dereham is offline Reply With Quote Quote
Old 10-11-2010   #2
Re: 1.4 8V tappet noise from cold
If its any help mine has been quite tappety since I got it (500 miles + on clock atm) and I would expect this with mechanical tappets, especially from cold. If it is knocking loudly then that is a different matter, as something could have given in the engine.
tyrebagga is offline Reply With Quote Quote
Old 10-11-2010   #3
Thanks, it's not knocking loudly, just a soft tapping noise from the top end until the engine is thoroughly warmed up then it's fine. Judging by the frequency it sounds like just one tappet is a tad noisy for some reason. If it gets any worse I'll take it in to Fiat, I guess no car is ever going to be perfect!
Old 11-11-2010   #4
its fine and normal
tom555tom is offline Reply With Quote Quote
Old 12-11-2010   #5
check your oil bud.
Engines will be a little tappety from cold until the oil gets up to temperature. However, an overly noisy engine indicates that it might be low on oil.
Keep it topped up
Willsevo is offline Reply With Quote Quote
Old 15-11-2010   #6
Thanks,
Oil level is fine, I notice in the service book that tappet clearance adjustment is part of routine maintenance at 36K miles. Didn't think they still made engines that needed that, brings back memories of many a happy hour under the bonnet with my feeler gauges! Anyway, not so worried now I know they can be adjusted.
Old 23-11-2010   #7
Smile Re: 1.4 8V tappet noise from cold *UPDATE*
Hi all, just coming up to 2K miles now and tappet noise almost completely gone and car definitely getting quicker as engine loosens. Happy to report no other faults at all so far, very pleased with this car. Bought it because my wife's Panda has not had a single fault since new 5 years ago (except for one recall).
(G) 1.2 8v tappet noise borisbbarnstable Doblo 5 21-01-2011 21:57
(T) Tappet Noise mafia11 Punto (Mk2/2b) 3 09-08-2008 12:29
(T) Tappet Noise - Exactly How To Fix It? *UPDATED* Ratters Cinquecento / Seicento 25 29-02-2008 13:18
(T) Tappet noise Djw Dave Uno 10 08-10-2007 21:40
(T) tappet noise IAN FLOWERS Bravo / Brava 6 13-12-2005 23:56
