Old 21-08-2010   #1
"Spirito Di Punto"
TJ07's Avatar
TJ07 has donated!
Evo Induction
Finally fitted after an afternoon of bruised knuckles & cut fingers, what a nightmare!
Thought I’d try and improve on Fiats placement of the air intake pipe, anyone else noticed that they have it positioned so that it can only suck in hot air from the engine bay?
Haven’t had a chance to take it out for a test run yet…. ran out of time, looks good though!
ID:	81275   Click image for larger version
Punto Evo Sporting 135 MultiAir Ambient White,
Red Wing Mirrors, Smoked Wind Deflectors, Team Dynamics Jet 17" alloys, Abarth Evo Exhaust & Suspension, Side Rubbing strips, Red Brake Calipers, Rear Mudflaps, Clear Rear Fog Unit, BMC Panel Filter, TMC Box, Osram Nightbreakers, Mtec Superwhite side lights, Mtec Superwhite DRL's, Chromed Indicator Bulbs, Smoked repeaters, Alloy Pedals, Armrest.
TJ07 is offline Reply With Quote Quote
Old 22-08-2010   #2
IronHorse has donated!
Re: Evo Induction
Be interesting to hear the feedback after a test drive, What model is the induction kit?
Multi-Air Turbo
IronHorse is offline Reply With Quote Quote
Old 22-08-2010   #3
Trader Rating: 1
Re: Evo Induction
let me no how it goes i have been considering a induction but waiting for some one brave to do it first on the multiair sporting
benjishearer is offline Reply With Quote Quote
Old 22-08-2010   #4
"Spirito Di Punto"
TJ07's Avatar
TJ07 has donated!
Talking Re: Evo Induction
Just had it out for a quick run today, throttle response seems slightly improved at lower revs also with it being a CDA kit you get a slightly improved grunt from the engine under acceleration, without sounding like a knob-mobile. You can also now hear the pshh from the dump valve (not loudly though, but it’s defiantly there).
Couldn’t get any idea of an improvement at the higher end as I was driving into what felt like a force 10 gale!
As for the kit, it was a nightmare to try and find something that would fit the multi-air as it does differ from the T-jet setup, I know this as I borrowed my old mans T-jet to check.
Also I noticed that most kits even designed for the T-jet are not suitable for UK models as the brake fluid tank is located in the way on the UK versions, and that’s the same on the Evo.
So after a lot of measuring and hunting I finally decided that a Simota WS-254-2 would fit best and they are very good filters to boot (yes I stuck a BMC sticker on it, just to make it look a bit more fitting for a Fiat… I know im sad!) I also had to order a different air feed pipe, one that was more flexible so that I could make it fit, I have the feed situated in the frontal wheel arch area as the air does seem to be cooler in that area.
Old 22-08-2010   #5
Trader Rating: 1
Re: Evo Induction
Quote Originally Posted by TJ07 View Post
nice how much did it set you back all together? im suprised it has not done anything top end. I love the pshh of the turbo at the moment would be nice to get it a little louder. my main concern was the warm air like you stated that will be around the filter my engine gets soooooooo hot after a quick wip around. not realy massive room to get a cold air feed in a sensible place.
Old 23-08-2010   #6
"Spirito Di Punto"
TJ07's Avatar
TJ07 has donated!
Re: Evo Induction
Managed to get a better test run today, definite improvement I’d say, not huge but noticeable. Also the point where I have the intake pipe situated defiantly pulls cooler air which helps too.
Quote Originally Posted by benjishearer View Post
I managed to get it done for about £150 (give or take)… think I got a fairly good deal.
(Tu) focus induction v gsr induction the result dave Punto (Mk2/2b) 73 12-10-2009 12:12
(G) 1.1 mpi induction kit Sonic74205 Cinquecento / Seicento 56 24-10-2007 12:57
(G) Sei mpi gsr induction dave Cinquecento / Seicento 30 15-08-2007 17:33
(G) Help with induction T3XAN May Punto (Mk2/2b) 0 27-07-2007 15:59
(T) Best induction kit - GT?? The Yellow Peril Punto (Mk1) 21 29-01-2007 14:21
